Polar coordinates (trig question)
In summary, the homework statement is to find cos(theta) then use inverse key to find sec(theta). The answer given in the solution guide is y=1/2 x^2. The Attempt at solution seems to work and the final result is y=1/2(x^2).
Oxygenate
Given r = 2tan(theta)sec(theta)
Find cos(theta) then use inverse key to find sec(theta)
The answer given in the solution guide is y = 1/2 x^2
Attempt at solution
Since tan = sin/cos and sec = 1/cos
We have r = 2sin/cos * 1/cos
So rcos^2 = 2sin
rcos^2 is defined as x^2 so x^2 = 2sin
Unless 2 sin is defined as 2 y, I don't see how we can get to y = 1/2x^2??
I do not understand where you got this part from:
In polar coordinates,
[tex]
x=r\cos\theta
[/tex]
and
[tex]
y=r\sin\theta
[/tex]
Substitute your expression for r into these two equations. Solve the first one in such a way that you can plug your result into the second one to solve for y in terms of x.
Oxygenate said:
So rcos^2 = 2sin
r cos^2 isn't the same as x^2. [tex]r^2 \cos^2 \theta = x^2[/tex].
For this problem just use the equations for converting between rectangular and polar coordinates, using the expression for cos theta and sine theta as hinted and substituting them into the problem equation.
Okay, so:
rcos = 2sin * 1/cos
x = 2sin * 1/cos
x = 2tan
Where does the x^2 come from and where does the y come from?
Don't worry about where the x^2 comes from, that is part of the answer and is a result of you solving the problem correctly.
You know that [tex]y=r\sin\theta[/tex] by definition. Find y as a function of theta only.
Then you can eliminate theta when you find y as a function of x only.
r = 2sin(theta)/cos(theta) * 1/cos(theta)
rcos^2 = 2sin(theta)
r^2cos^2 = r2sin(theta)
x^2 = 2y
y = 1/2(x^2)
It seems like this works too. Thanks! I haven't done trig in like forever...
FAQ: Polar coordinates (trig question)
What are polar coordinates?
Polar coordinates are a system of representing points in a plane using a distance from the origin and an angle from a fixed reference line. They are often used in mathematics and physics, particularly in studying circular and periodic phenomena.
How do you convert between polar and cartesian coordinates?
To convert from polar to cartesian coordinates, use the formulas x = r cos(theta) and y = r sin(theta), where r is the distance from the origin and theta is the angle. To convert from cartesian to polar coordinates, use the formulas r = sqrt(x^2 + y^2) and theta = arctan(y/x).
What is the relationship between polar coordinates and trigonometry?
Polar coordinates and trigonometry are closely related because the distance from the origin and the angle from a reference line in polar coordinates can be represented using trigonometric functions. In particular, the x-coordinate in cartesian coordinates is equal to r cos(theta), and the y-coordinate is equal to r sin(theta).
How do polar coordinates relate to polar graphs?
Polar coordinates are often used to graph polar equations, which are equations that relate the distance from the origin and the angle to each other. These graphs can take on various shapes, including circles, spirals, and cardioids.
What are some real-world applications of polar coordinates?
Polar coordinates have various real-world applications, including in navigation and mapping systems, in physics and engineering for analyzing circular motion and oscillations, and in astronomy for studying the orbits of planets and other celestial bodies.
