Polar Covalent Bond in HCl question
  • Thread starter Thread starter ProjectFringe
    Bond Hcl Polar
The polar covalent bond in HCl results in a polar molecule due to its asymmetrical structure. While the partially positive hydrogen can attract negative ions and the partially negative chlorine can attract positive ions, the interactions are not strong enough to create a chain of HCl molecules, as seen in hydrogen bonding. The attraction between HCl molecules is minimal compared to stronger hydrogen bonds found in compounds like HF. HCl's weaker dipole interactions affect its boiling point, which is significantly lower than that of HF. Overall, HCl behaves as a strong acid, reacting readily with various salts.
ProjectFringe
If my understanding is correct, the polar covalent bond in HCl creates a polar molecule because the molecule is unsymmetrical.
1. Does this mean that the partially positive H of one HCl molecule will be attracted to the partially negative Cl of another HCl molecule and vice versa, to create a chain of HCl? If so, what is this called?
2. In regards to an HCl molecule, does this also mean that the partially positive H can attract negative ions and the partially negative Cl can attract positive ions from another compound such as KCl?
Chemistry news on Phys.org
1. I'm assuming you are talking about hydrogen bonding-like behavior. In that sense, it sort of happens but the attraction is much much smaller than e.g. oxygen and nitrogen. This is because although chlorine have high electronegativity, due to its atom size, the electron density is not high enough for hydrogen bonding. As such, it's improbable that it creates a chain of HCl.
2. Due to the reason above, I don't think you can observe a hydrogen bond-like behavior or significant attraction for chlorine atom in HCl. The dipole attraction do happen to some extent though, and this affects the boiling point. As for hydrogen bond for the hydrogen in HCl, hydrogen bond between fluorine of HF and hydrogen of HCl has been documented before (HF-HCl complex).
https://aip.scitation.org/doi/abs/10.1063/1.434691
Likes ProjectFringe
Got it! Thanks:biggrin:
It probably does not happen, but if it does, it would be called "associate".
Compare HF. HF has molar mass of 20. It boils at +19 Celsius. And even above the boiling point, the molar mass of vapour is much bigger than 20, non-integer and varies strongly with temperature and pressure - at room temperature it is around 50 or so. The reason is that the vapour has equilibrium of various hydrogen bonded associates - (HF)2, (HF)3, some HF and so on, which equilibrium easily shifts.
In contrast, HCl boils at -85, and the vapour seems to be mostly lone molecules.
The reason is that H is much smaller than Cl. With the smaller F, H can give both polar covalent bond and hydrogen bond. With Cl, the polar covalent bond is weaker, and hydrogen bond cannot be formed.
It can attract negative ions - which is why HCl is a strong acid and reacts with a lot of salts. Like
HCl+F-=HF+Cl-
Partially negative Cl can attract positive ions from another compound. Actually not KCl, specifically, because K+ has a closed electron shell. On the other hand, partially negative Cl readily attracts positive ions from compounds like AlCl3.
Likes ProjectFringe
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
