Polarizers in series, I got the correct answer, want to verify why
  • Thread starter Thread starter breakingaway
    Series
The discussion revolves around calculating the orientation of the third polarizer in a series of three, given an unpolarized laser beam and its power transmission through the polarizers. The user correctly applies the formula for power transmission through polarizers, confirming that the exponent for the transmission factor corresponds to the number of identical polarizers. Clarification is sought on the angle adjustments in the cosine function, particularly how the angle of the previous polarizer affects the calculation for the subsequent one. The user proposes a scenario with an additional polarizer and seeks confirmation on the angle adjustments needed for accurate calculations. The conversation emphasizes understanding the relationship between polarizer orientation and power transmission.
breakingaway
An unpolarized laser emits 1.00 W of continuous optical power.
It's beam is directed into three identical linear polarizers, each with a maximum transmission of 95.0%. The first polarizer has its transmission axis vertical, the second at 45.0 from the vertical, and the third is in an unknown orientation. An optical power meter reads the overall power transmitted as 5.50 milliwatts. Find the orientation of the third polarizer's transmission axis relative to the vertical. (20 points)
I = Imax*1/2 * cos212)
So I set up the equation as such:
5.5*10-3= (0.95)3*1.0W*1/2 * cos2(90°-45°)*cos2(θ - 45°)
I do some algebra and get θ = 125.78, which is the correct answer.
What I'm looking to clarify is a few things.
For the (0.95)3 part of the equation, the exponent will always just be the number of polarisers if they all have the same maximum transmission?
cos2(θ - 45°), the -45° comes from the previous polariser right? So if there was another polariser that had an angle 60° from the vertical place before the last unknown polariser, the equation would change to:
5.5*10-3= (0.95)4*1.0W*1/2 * cos2(45°)*cos2(60°-45°)*cos2(θ - (60°-45°))
Is this correct? I'm not 100% certain and I don't have access to any more problems in the same form as this one that I have the answer to.
Thank you in advance.
Right
I think the angles should be 45°, 15° (=60-45) and θ-60°, as θ is measured relative to the vertical axis.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
