Poloidal current in toroidal solenoid
The discussion centers on defining the current density for a poloidal current in a toroidal solenoid. The user presents a mathematical definition of a torus using conical and spherical rings, and provides a formula for the poloidal current density. They express concern about the smoothness of the torus and its homeomorphism to the standard torus, questioning its relevance to physics. Additionally, they seek guidance on expressing current density in spherical coordinates for a standard toroidal solenoid, acknowledging that the resulting equations may become complex. The user aims to solidify their understanding of current density before proceeding with calculations related to the multipole expansion of electromagnetic fields.
Mr. Rho
Hi, I'm trying to figure out how the current density for a poloidal current in toroidal solenoid is written. I found you may define a torus by an upper conical ring ##(a<r<b,\theta=\theta_1,\phi)##, a lower conical ring ##(a<r<b,\theta=\theta_2,\phi)##, an inner spherical ring ##(r=a,\theta_{1}<\theta<\theta_{2},\phi)## and an outter spherical ring ##(r=b,\theta_{1}<\theta<\theta_{2},\phi)##. I used Mathematica to illustrate the torus generated with this definition:
So, the poloidal current density may be weitten:
\mathbf{J}(\mathbf{r})=\frac{NI}{2\pi r\sin\theta}\lbrace\frac{\hat{r}}{r}[\delta(\theta-\theta_{1})-\delta(\theta-\theta_{2})][\Theta(r-a)-\Theta(r-b)]+\hat{\theta}[\delta(r-b)-\delta(r-a)][\Theta(\theta-\theta_{1})-\Theta(\theta-\theta_{2})]\rbrace
My question is: is that definition of a torus correct? my problem here is that this torus is not smooth, so I don't know if it is homeomorphic to the standard torus (I don't know much about Topology). Also I would like to know if there is a possible way to write a current density in spherical coordinates for a poloidal current in a standard toroidal solenoid:
Thank you for your answers (:
It is, but I don't see how this could be relevant in a physics problem.
Sure, but the equations could get messy.
Thank you, I'm studying the multipole expansion of EM fields for such toroidal solenoid but I want to feel confortable with the current density before start to calculate things...
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
