Polymer Solution Thermodynamics: Flory-Huggins Theory of Polymer Solutions
The discussion revolves around the derivation of the partial molar Gibbs free energy of mixing using the Flory-Huggins theory. The user is struggling with the mathematical aspects, particularly with taking partial derivatives of the Gibbs free energy equation. They have made progress by expressing volume fractions in terms of the number of moles and have attempted to break down the equation into manageable parts. Feedback from other participants emphasizes the importance of careful calculation in the derivatives and clarifies that certain assumptions about constants are valid. Ultimately, the user reports achieving the correct equation after guidance.
tetrakis
(Note: This isn't an assignment problem, more a curiosity about the derivation of an equation - hopefully it is still posted in the right forum..)
I have working through the derivation for the partial molar Gibbs free energy of mixing from the Flory-Huggins expression for the Gibbs free energy of mixing, however my math skills are (very) rusty - especially when it comes to partial derivatives.
Gibbs Free Energy of Mixing (Flory-Huggins Theory):
ΔGM=R·T[n1·ln(ϕ1)+n2·ln(ϕ2)+n1·
·ϕ2]
partial molar Gibbs free energy of dilution:
Δμ1=R·T[ln(1-ϕ2)+(1-1/r)·ϕ2 +
·ϕ22]
where
KB=Boltzmann Constant,
ni=number of moles of i,
ϕi=volume fraction of i,
=Flory-Huggins Interaction Parameter
ϕ1=N1/N0=N1/(N1+r·N2)
ϕ2=(r·N2)/N0=(r·N2)/(N1+r·N2)
N0=N1+r·N2
where
N0 is the number of lattice sites
N1 is the number of solvent molecules
N2 is the number of polymer molecules, each occupying "r" lattice sites (or "r" segments)
and R=KB·NA
where
NA= Avogadro's constant
·ϕ2]
applying R=KB·NA
ΔGM=KB·T[N1·ln(ϕ1)+N2·ln(ϕ2)+N1·
·ϕ2]
expressing ϕ1 and ϕ2 in terms of N1 and N2 gives
ΔGM=KB·T[N1·ln(N1/(N1+r·N2))+N2·ln((r·N2)/(N1+r·N2))+N1·
·(r·N2)/(N1+r·N2)]
Next step would be to take the partial derivative of the equation with respect to N1, I've tried many times but I cannot get anything close to the equation for the partial molar Gibbs free energy of dilution..
I broke it up, letting
Ψ1=N1·ln(N1/(N1+r·N2))
Ψ2=N2·ln((r·N2)/(N1+r·N2))
Ψ3=N1·
·(r·N2)/(N1+r·N2)
taking the partial derivative
1/dN1=ln(N1/(N1+rN2)+[1-(N1+rN1N2)/(N1+rN2)]
2/dN1=-N2[(1+rN2)/(N1+rN2)]
2/dN1=
[(rN2)/(N1+rN2)]+N1
[(-rN2)/(N1+rN2)2
which when I plug it all back in, gives me a big mess..
ΔGM=R·T[n1·ln(ϕ1)+n2·ln(ϕ2)+n1·[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png·ϕ[SUB]2[/SUB]]
Δμ1=R·T[ln(1-ϕ2)+(1-1/r)·ϕ2 +[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png·ϕ[SUB]2[/SUB][SUP]2[/SUP]]
where
[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png=Flory-Huggins Interaction Parameter
N0=N1+r·N2
where
and R=KB·NA
where
applying R=KB·NA
ΔGM=KB·T[N1·ln(ϕ1)+N2·ln(ϕ2)+N1·[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png·ϕ[SUB]2[/SUB]]
ΔGM=KB·T[N1·ln(N1/(N1+r·N2))+N2·ln((r·N2)/(N1+r·N2))+N1·[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png·(r·N[SUB]2[/SUB])/(N[SUB]1[/SUB]+r·N[SUB]2[/SUB])]
Ψ3=N1·[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png·(r·N[SUB]2[/SUB])/(N[SUB]1[/SUB]+r·N[SUB]2[/SUB])
3/dN1=[PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png[(rN[SUB]2[/SUB])/(N[SUB]1[/SUB]+rN[SUB]2[/SUB])]+N[SUB]1[/SUB][PLAIN]https://upload.wikimedia.org/math/7/9/c/79c40dd2b43f3c03eaf88b5fc4c199b8.png[(-rN[SUB]2[/SUB])/(N[SUB]1[/SUB]+rN[SUB]2[/SUB])[SUP]2[/SUP]
Start out with ##\frac{\partial \psi _3}{\partial n_1}##. You need to reduce the rhs to the least common denominator. You almost have it. At least get that term.
Chet
Likes tetrakis
Chet
Hey Chet,
Thanks for the help, I've got the third term now. Am I even close with the other 2 terms? I've been playing around with them a bit more, but I can't quite seem to get it, especially the first term with the ln(1-ϕ2)
for ##\frac{\partial \psi _2}{\partial N_1}## I'm taking ##\frac{\partial N _2}{\partial N_1}## and ##\frac{\partial ln(rN_2)}{\partial N_1}## as zero based on the assumption that it is similar to taking the derivative of a constant, would this be correct?
This is correct. But your partial derivatives of psi1 and psi2 with respect to n1 are both incorrect. You need to be more careful. Try again.
Also note the phi1 = 1 - phi2
Chet
Chet
Thank you, I've gotten the correct equation now.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
