Polynomial Algebra: Show Alpha is Power of Prime p
  • Thread starter Thread starter Coolster7
    Algebra Polynomial
Coolster7
Let f(x) = anxn + an-1xn-1 + ... + a1x + a0 be a polynomial where the coefficients an, an-1, ... , a1, a0 are integers.
Suppose a0 is a positive power of a prime number p.
Show that if \alpha is an integer for which f( \alpha ) = 0, \alpha is also a power of p.
I substituted \alpha into the equation in the place of x for each term. I also substituted in pn in the place of a0 as this is a positive power of a prime number p (as given in the question). This gave me:
f(\alpha) = an\alphan + an-1\alphan-1 + ... + a1\alpha + pn = 0
I then decided to isolate pn by moving the other terms to the other side of the equation which gave me:
pn = -{an\alphan + an-1\alphan-1 + ... + a1\alpha}
Is what I have done so far correct? I now have to show from this that \alpha is also a power of p. I'm unsure what the next step is to do that.
Can anyone help please?
Do you know the rational root theorem?
You are correct so far. If you factor out alpha, then you will have that alpha divides ##p^n##.
Likes 1 person
Thanks for your help. So because alpha divides p^n this means alpha is also a power of p I'm assuming.
Yep!
Likes 1 person
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
