Polynomial Challenge: Find # of Int Roots of Degree 3 w/ Coeffs
In summary, The Polynomial Challenge: Find # of Int Roots of Degree 3 w/ Coeffs is a mathematical problem that involves finding the number of integer roots of a polynomial equation with a degree of three and given coefficients. A polynomial equation is an algebraic equation that contains one or more terms with variables raised to positive integer powers. To find the number of integer roots of a polynomial equation, you can use the Rational Root Theorem, which states that any rational root of a polynomial equation is a factor of the constant term divided by the leading coefficient. The degree of a polynomial equation is the highest exponent of the variable in the equation. Finding the number of integer roots is important in polynomial equations because it helps determine the solutions or the x-inter
anemone
MHB
POTW Director
3,883
115
If $P(0)=3$ and $P(1)=11$ where $P$ is a polynomial of degree 3 with integer coefficients and $P$ has only 2 integer roots, find how many such polynomials $P$ exist?
Mathematics news on Phys.org
beacuse P(0) is odd it does not have any even root and because P(1) is odd it does not have any odd root. So it cannot have any integer roots. So there is no polynomial.
reason : P (a) - P(b) is divisible by a - b
the above is based on http://mathhelpboards.com/linear-abstract-algebra-14/polynomal-divisibility-10507.html#post48739
Hi kaliprasad,
Thanks for participating and the follow-up explanation post! I also want to thank you for your continuous support to my challenge problems!:)
for convenience we let the leading coefficient=1, then :
$P(x)=x^3+ax^2+bx+3$
$P(1)=1+a+b+3=11$
$\therefore a+b=7$-----(1)
if m,n are 2 intger roots of $ P(x)$ then m.n must be a factor of 3
if $P(-1)=0$ we have $-1+a-b+3=0, \,, =>a-b=-2---(2)$
from (1)(2)
$a=\dfrac {5}{2}$
does not fit (since a must be integer)
if $P(3)=0 $
we have $27+9a+3b+3=0, \,, =>3a+b=-10---(3)$
if $P(-3)=0$
we have $-27+9a-3b+3=0\,, =>3a-b=8----(4)$
from (1)(3) and (1)(4) we find both "a" are not integer
and we conclude such P(x) does not exist
FAQ: Polynomial Challenge: Find # of Int Roots of Degree 3 w/ Coeffs
What is the Polynomial Challenge: Find # of Int Roots of Degree 3 w/ Coeffs?
What is a polynomial equation?
A polynomial equation is an algebraic equation that contains one or more terms with variables raised to positive integer powers. It can have multiple terms and may also include constants and coefficients.
How do you find the number of integer roots of a polynomial equation?
To find the number of integer roots of a polynomial equation, you can use the Rational Root Theorem, which states that any rational root of a polynomial equation is a factor of the constant term divided by the leading coefficient. By testing the possible rational roots, you can determine the number of integer roots.
What is the degree of a polynomial equation?
The degree of a polynomial equation is the highest exponent of the variable in the equation. For example, in the equation 3x^2 + 5x + 2, the degree is 2.
Why is finding the number of integer roots important in polynomial equations?
Finding the number of integer roots is important in polynomial equations because it helps determine the solutions or the x-intercepts of the equation. These integer roots are also known as rational roots and can provide valuable information about the behavior and properties of the polynomial function.
