Portable telescopes inside the International space station (ISS)
In summary, the portable telescope on the ISS is likely to have a limited view due to atmospheric distortion. It would be useful for viewing planets and stars from Earth, but is not as good as Hubble or other larger telescopes.
akerkarprashant
74
TL;DR Summary
Portable telescopes inside the International space station.
I would like to know what will be the visibility from the portable telescope aboard the International Space Station.
What could they potentially view, and what are (at least some of) the things they are known to have looked at?
Presumably they use it *inside* the ISS and not outside, and are therefore constrained by there needing to be a window providing access, to the sky, and the window should have good optical quality to preserve the resolution of the telescope?
Astronomy news on Phys.org
Do you have any links to information about this telescope that you can post?
Likes akerkarprashant
Thanks.
No. General curiosity whether as we the Sky from ground level, with different telescopes, what could be the different views as seen from ISS (470 kilometres above Earth) with different telescopes?
akerkarprashant said:
No.
Perhaps Google could help you find some links to post for us to read? Where did you first hear/read about this?
There would be no essential difference, apart from the elimination of atmospheric distortion and filtering replaced by the effects of a window glass in between.
If you look at the display that Stellarium will give you (that's a free planetarium program which everyone should have), that would give you the best idea of just how much the atmosphere spoils our view from Earth. (Stellarium allows you to turn it on and off). There are limitations to the application and the view through a good telescope on a good night will actually look different - smaller, sharper stars than even a good monitor will show and the magnitudes are not too convincing but you can always zoom in and out to get what you want. Learning to drive the App takes time so don't blame it until you are familiar with all the quirks.
Any telescope that could be taken on board for 'personal observations' would have to be pretty small and storable, away from ongoing work on ISS. All the same limitation for visual observing will be there and multiple, long photographic exposures will give much better results than you get in your garden. You would still need clever guiding to eliminate the problems as crew members wander around, doing their duties and the craft pitches and yaws during an exposure. Hubble and its smaller cousins doesn't have to deal with that; people in space can be a damn nuisance.
Likes berkeman and akerkarprashant
FAQ: Portable telescopes inside the International space station (ISS)
How are portable telescopes brought inside the ISS?
The portable telescopes are typically brought inside the ISS during resupply missions. They are packaged and stored in cargo spacecrafts such as the SpaceX Dragon or the Russian Progress spacecraft. Astronauts then unpack and assemble the telescopes inside the ISS.
How are the portable telescopes powered inside the ISS?
The portable telescopes inside the ISS are powered by electricity, which is generated by solar panels on the exterior of the station. The telescopes are connected to the ISS power grid and can also be powered by batteries if needed.
What types of portable telescopes are used inside the ISS?
The ISS has multiple types of portable telescopes, including optical telescopes such as the Celestron CPC 800 and the Meade LX200, and radio telescopes such as the Space Station Radio Telescope (SSRT). These telescopes are used for various types of astronomical observations and research.
How are the portable telescopes maintained and repaired inside the ISS?
The portable telescopes inside the ISS are maintained and repaired by the astronauts on board. They are trained in basic telescope maintenance and can perform tasks such as cleaning lenses, replacing parts, and troubleshooting technical issues. If necessary, the telescopes can also be sent back to Earth for more extensive repairs.
What types of objects can be observed with portable telescopes inside the ISS?
The portable telescopes inside the ISS can observe a wide range of objects in space, including planets, stars, galaxies, and other celestial bodies. They can also be used to study phenomena such as supernovas, black holes, and gravitational waves. The telescopes are also used for Earth observation, such as tracking weather patterns and monitoring natural disasters.
