Position measurement in Non-Relativistic QM
In summary: It is generally believed that this is not possible as the wave function would collapse to a delta function, which is not a legitimate wave function. However, the collapse rule can be generalized and there is a measurement model that allows for a sharp position measurement. This is summarized in a paper by Ozawa. In practical terms, measuring position with an arbitrarily good finite precision is equivalent to measuring it with infinite precision. This is because a state with perfect position is a Dirac Delta Function, which is not a function and does not belong to a Hilbert space.
andresB
626
374
I've read several times in textbooks that in NR-QM you can measure with exact precision the position of a particle if you don't care at all for the momentum (because the uncertainty of the momentum will be infinite), it always seemed reasonable enough for me but now that I think about it, it should be impossible in principle because the wave function would collapse to a delta function, and the delta function is not in the hilbert space of the wave functions.
Any thoughts?
The quick answer is that one doesn't need collapse unless one is doing another measurement after the first. So we can just declare the measurement done, and the particle destroyed after that.
However, the collapse rule is actually more general, and doesn't have to be a projection onto an eigenvector of the observable. The heuristic way to see this is that what you consider a measurement is subjective, so you can collapse it onto the eigenvector and rotate it, and call that process the measurement.
OK, but that still doesn't help with continuous variables, since the eigenvector itself is not a legitimate wave function. For continuous variables the collapse is defined by Eq 3 of http://arxiv.org/abs/0706.3526. Remarkably, Ozawa discovered that there is a measurement model that will give a sharp position measurement, which is summarized in section 2.3.2 of that paper.
Likes Greg Bernhardt
Any thoughts?
That means that you cannot measure position with infinite precision, but you can measure position with an arbitrarily good finite precision. For all practical purposes, this is the same.
Likes bhobba
This is seen by the fact a state with perfect position is a Dirac Delta Function - which isn't really a function, and certainly doesn't belong to a Hilbert space.
Thanks
Bill
Related to Position measurement in Non-Relativistic QM
1. What is the significance of position measurement in non-relativistic quantum mechanics?
Position measurement is a fundamental aspect of non-relativistic quantum mechanics as it allows us to determine the location of a particle in space. This is crucial for understanding the behavior and properties of particles, as well as for making predictions about their movement and interactions with other particles.
2. How is position measured in non-relativistic quantum mechanics?
In non-relativistic quantum mechanics, position is measured using a wave function, which describes the probability of finding a particle at a particular location. The wave function is then squared to obtain the probability density, which gives the likelihood of finding the particle within a specific region of space.
3. Can position be precisely measured in non-relativistic quantum mechanics?
No, according to the Heisenberg uncertainty principle, it is impossible to simultaneously know the exact position and momentum of a particle. This means that there will always be some degree of uncertainty in the measurement of position in non-relativistic quantum mechanics.
4. How is the measurement of position affected by the observer in non-relativistic quantum mechanics?
In non-relativistic quantum mechanics, the act of measuring the position of a particle can change its state. This is known as the observer effect and is a fundamental aspect of quantum mechanics. The observer's interaction with the particle alters its wave function, leading to different probabilities for its position measurement.
5. How does the measurement of position in non-relativistic quantum mechanics differ from classical mechanics?
In classical mechanics, position is a well-defined, measurable quantity, whereas in non-relativistic quantum mechanics, it is described by probability. Additionally, in classical mechanics, the measurement of position does not affect the state of the particle, while in quantum mechanics, it does. This demonstrates the fundamental differences between the two theories and the limitations of classical mechanics in describing the behavior of particles at the quantum level.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
