Undergrad Position operator explicit form
The discussion centers on the correct representation of the position operator ##\hat{x}## in Dirac notation. A participant questions whether the expression $$\bra{x}\hat{x} = \bra{x}x$$ contains a typo, suggesting it should be $$\bra{x}\hat{x} = x \bra{x}$$ instead. Clarifications reveal that the ##x## in the expression is an eigenvalue and not a function, allowing it to be factored out correctly. The conversation emphasizes the importance of notation in quantum mechanics, particularly how scalars and vectors are represented. Ultimately, the participants agree on the subtleties of the notation and its implications for understanding the position operator.
cianfa72
TL;DR
About the position explicit form definition
I've a doubt about the following definition from PSE thread.
The first answer says that the position representation of the position operator ##\hat{x}## is:
$$\bra{x}\hat{x} = \bra{x}x$$ I believe there is a typo, it should actually be $$\bra{x}\hat{x} = x \bra{x}$$
Does it make sense ? Thanks.
cianfa72 said:
TL;DR Summary: About the position explicit form definition
In standard linear algebra we tend to write the scalar before a vector. In Dirac notation, however, it's important to write the scalar after a bra. That allows all the typographical wizardry of Dirac's notation.
Likes Demystifier
Ok, however applying the operator ##\hat{x}## to the state/vector ##\ket{\psi}##, one gets $$\bra{x}\hat{x} \ket{\psi} = \bra{x}x\ket{\psi}$$ and, by defining the wavefunction ##\psi(x):=\braket{x|\psi}##, one doesn't get the expression $$\bra{x}\hat{x} \ket{\psi} = x\psi(x)$$ as expected...
Well, yes you do. Note that in general:
$$\langle \phi |\hat A |\psi \rangle = \langle \psi |\hat A^{\dagger}|\phi \rangle^*$$
Actually, you don't need that in this case:
$$\langle x|x|\psi\rangle = x \langle x|\psi \rangle$$As the ##x## that comes out is a number/eigenvalue.
Ah ok...so the ##x## that comes out isn't a function, it is just a number (actually the eigenvalue) let's say associated with the specific position eigenstate ##\ket {x}##.
Therefore, since it is just "a real number", it comes out from the inner product.
It's a function value. The inner product itself is a functional, I.e. a function/mapping into the complex numbers.
We can define a complex valued function on the real numbers as follows. For each real number ##x## we have:
$$f(x) = \langle x |\hat x|\psi\rangle = \langle x|x|\psi\rangle = x \langle x|\psi \rangle = x\psi(x)$$
PS note the subtlety that ##\hat x## is the position operator and is not dependent on ##x##, which represents a specific real number and eigenstate associated with that real number.
Multiplication of a vector by a scalar is commutative, i.e. ## x\bra{x}=\bra{x}x##.
In other words, for a given ##x## value (say ##x=2##) the relevant specific real number (eigenvalue) and eigenstate are 2 and the bra ##\bra{2}## respectively -- the latter is the dual vector associated via musical isomorphism with the ket ##\ket{2}##.
  • · Replies 59 ·
  • · Replies 32 ·
