Position pointer to specific line in a file
In summary: post, most programming languages/operating systems can read directly from a specified position in a file.
Anyname Really
TL;DR Summary
Is it possible, and if so, in what language, to read a specific line of a file without reading the lines before it?
I would like to read a specific line of a file. Everything I have seen does it by reading the file from the top, ignoring what is read until the line of interest is reached. Is it possible to move the pointer of the reader to the line directly, say by counting the number of line end sequences. Is the problem easier to solve if every line of data has the same format?
Technology news on Phys.org
If the lines are all of a fixed length then it is possible to seek into a file to a specific line start otherwise no.
In most text files, lines are of varying length and it is not possible to seek into the file at the start of a given line without some sort of prebuilt index of seek values. One can create an index and as long as the file doesn't change ie lines added, updated or deleted then it can be used to locate a specific line.
Python, Java, C and Go come to mind as languages with a seek function.
Here's a discussion using python:
https://pynative.com/python-file-seek/
and java
https://www.tutorialspoint.com/java/io/randomaccessfile_seek.htm
and in c:
https://www.scaler.com/topics/c/random-access-file-in-c/
and in golang:
https://golang.hotexamples.com/examples/os/File/Seek/golang-file-seek-method-examples.html
other languages that read files should have similar strategies.
Lastly, python programmers usually read in the whole file into an array that can be easily accessed which of course takes up a larger amount of memory than the seek+index table would.
How are you going to count line endings without reading the file?
Yes, most programming languages/operating systems can read directly from a specified position in a file.
Interesting. I just got two responses which seem to contradict one another. The first makes more sense. Maybe I am asking for the impossible. A partial solution would be to know how a computer knows where it is in a file. I suppose, the complier, in a language such as C++, has some internal variable which indicates where it is in a file. If so, is it possible to access this variable directly?
I don't think they do, they both state the obvious which is that if you know what position you want to go to then you can go to it but if you don't you can't.
Why don't you follow the links in @jedishrfu' s post, these will tell you all you need to know. I would not recommend C++ for someone starting out in programming.
I don't see any contradiction either. A text file is a string of characters, each taking up one byte. Thus you can easily skip to (e.g.) the 3047th character in a file without reading the previous 3046 in most languages just by asking the file system to give you the character 3046 characters after the start position of the file.
What you can't do without reading the 3046 characters is know how many "end of line" characters you skipped, so you can't generally skip to the 453rd line. You can do it if you know that all your lines are guaranteed to be (e.g.) 80 characters long, by skipping to character 80×453. Alternatively, if you have an index file (perhaps with fixed length entries) that tells you what character number line 453 starts at you can then skip to that character. But both of these strategies rely on having extra information about the file.
Likes pbuk
Many text files use UTF-8 encoding so some characters may take up more than one byte. Because of this you need to be careful when seeking into a text file.
Likes jedishrfu and Ibix
They don't contradict : you just don't have enough basic knowledge of the subject matter.
You can look up "relative record data set" for IBM's implementation. It's a system level component of VSAM (probably ISAM as well). I'd be mildly surprised (not shocked though) if you couldn't find PC software that does it. No clue what keywords to use for that search.
But, if the file is small enough that it can be stuffed into an array, it's almost trivial to write a file handler as a program subroutine, in pretty much any language. Could easily do variable-length records, as well, using another array as an index.
As was previously mentioned in the "contradictory" posts.
One further point is that you might start in the middle of a multi-byte character and thus get buggy results.
Likes Ibix
FAQ: Position pointer to specific line in a file
How do I move the position pointer to a specific line in a file?
To move the position pointer to a specific line in a file, you can use the fseek() function in C or the seek() method in Python. Both of these allow you to specify the line number or byte offset you want the pointer to move to.
Can I move the position pointer to a line that contains a specific word or phrase?
Yes, you can move the position pointer to a line that contains a specific word or phrase by using the fgets() function in C or the readline() method in Python. These functions will read each line of the file until the specified word or phrase is found, and then move the pointer to that line.
How can I check the current position of the pointer in a file?
You can use the ftell() function in C or the tell() method in Python to check the current position of the pointer in a file. These functions will return the byte offset of the pointer from the beginning of the file.
What happens if I try to move the position pointer beyond the end of the file?
If you try to move the position pointer beyond the end of the file, it will result in an error. It is always important to check the size of the file before attempting to move the pointer to ensure it is within the file's boundaries.
Can I move the position pointer to a specific line in a binary file?
Yes, you can move the position pointer to a specific line in a binary file by using the fseek() function with the appropriate offset and reference point. However, since binary files do not have lines in the traditional sense, the pointer will move to the specified byte offset instead of a specific line.
