Position, Velocity, Acceleration
In summary, an arrow shot with an initial velocity of 49 m/sec is shot straight up and rises to a maximum height of 176 ft before it hits the ground. The car stops after 176 ft.
thaaampie
A car is going 60mph (88ft/second) when it suddenly applies the brakes at time t=0 and skids (with constant deceleration) for 176 ft until it stops. What was the rate of deceleration? How long did it take before the car stopped?
An arrow was shot straight up from the ground at time t=0 seconds with an initial velocity of 49 m/sec. Assuming that the free-fall acceleration is -g=-9.8 m/sec^2, determine its maximum height, and when it hits the ground.
For the first problem you will want to use the following formula:
[tex]v_2^2=v_1^2+2ax[/tex]
Remember that the car will eventually come to rest, so your final velocity will be 0 m/s. For the second part, you can use any other kinematic equation.
The second problem is very similar. At the maximum height, the velocity will be 0 m/s. The same formulas can be used. Just remember that when finding the time to hit the ground, the arrow must travel up and back down.
If you work the problems yourself and want somebody to check if they are right, or if you have more trouble with them, post back with your attempt at the solution and your answers and I will check them for you.
I would do those slightly differently from Nex Vortex. If the constant acceleration is -a, then the speed at time t is [itex]v(t)= v(0)- at= 88- at[/itex] and the distance moved is [itex]x(t)= 88t- (a/2)t^2[/itex]. Saying that the car stops after 176 feet means that [itex]v(t)= 88- at= 0[/itex] and that [itex]88t- (a/2)t^2= 176[/itex] so that you have two equations to solve for a and t.
Similarly, for the second problem, the velocity of the arrow (positive upward) at time t is [itex]v(t)= 49- 9.8t[/itex] and its height is [itex]x(t)= 49t- 4.9t^2[/itex]. Set the second fomula equal to 0 to find the time it hit the ground. set first equation equal to 0 to solve for the time of its highest point (at that point it is no longer going up, so v(t) is not positive but it is not yet going down so v(t) is not negative) and put that t into the equation for x(t) to find the actual height.
Related to Position, Velocity, Acceleration
1. What is position?
Position refers to the location of an object in space at a specific point in time. It is typically measured in terms of distance and direction from a reference point or origin.
2. How is velocity defined?
Velocity is defined as the rate of change of an object's position over time. It is a vector quantity that includes both magnitude (speed) and direction.
3. What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a vector quantity that includes both magnitude and direction. An object can accelerate if it changes its speed, direction, or both.
4. How are these three concepts related?
Position, velocity, and acceleration are all related to an object's motion in space. Acceleration is the derivative of velocity with respect to time, and velocity is the derivative of position with respect to time. This means that acceleration is the rate of change of an object's velocity, and velocity is the rate of change of an object's position.
5. What are some real-world examples of these concepts?
Position, velocity, and acceleration are important concepts in physics and are used to describe the motion of objects in many real-world scenarios. For example, a car's position can be described in terms of its distance from a starting point, its velocity can be measured in miles per hour, and its acceleration can be calculated when the driver presses on the gas pedal or applies the brakes. Other examples include the motion of planets in space, the acceleration of a roller coaster, and the velocity of a baseball being thrown by a pitcher.
