Potential and Kinetic Energy on a swing as well as Tension in the rope
In summary, a 23.0 kg child is on a swing with support ropes that are 2.10 m long. The ropes are pulled back 41.0 degrees from the vertical and the child is released from rest. Part (a) asks for the comparison between the potential energy at the top and bottom of the swing. The potential energy at the top is 473 J, and at the bottom it is equal to the kinetic energy. Part (b) asks for the speed of the child at the bottom of the swing, which is found to be 6.42 m/s. Part (c) asks for the work done by the tension in the ropes as the child swings from the initial position to the bottom.
lesleymarie785
A 23.0 kg child plays on a swing having support ropes that are 2.10 m long. A friend pulls her back until the ropes are 41.0-degrees from the vertical and releases her from rest.
a.)What is the potential energy for the child just as she is released compared with the potential energy at the bottom of the swing?
b.) How fast will she be moving at the bottom of the swing?
c.) How much work does the tension in the ropes do as the child swings from the initial position to the bottom?
Potential Energy (U) = mgr
Kinetic Energy (K) = 05*m*v^2
W(noncons force) = ΔE = E(initial) + W(nc) = E(final)
a.) U(top)= mgr
Potential energy at the top = (mass of child)(gravity)(radius or length of ropes)
= 23kg * 9.8m/s^2 * 2.10m
U(top) = 473 J
b.) U(top) = KE(bottom) so, mgr = .5mv^2
Mass cancels as it is on both sides of the equation, so you're left with: gr = .5v^2
2gr = v^2 then square-root the whole thing to yield 2gr^.5 = v
v = (2*9.8*2.10)^.5
v = 6.42 m/s
c.) I think nonconservative forces Work equation should come into play here:
W(nc) = ΔE
E(i) + W(nc) = E(f) or E(i) = E(f) + W(nc) <--not sure which way this should go. Also not sure how to go about solving for the Tension.
Thank you so much for any help.
W(nc) = ΔE
E(i) + W(nc) = E(f) or E(i) = E(f) + W(nc) <--not sure which way this should go. Also not sure how to go about solving for the the Tension.
Not sure why you think non-conservative forces apply here. Usually these are things like friction and air resistance. The big hint here is that this is a bit of a trick question. Look back at the definition of what work is.
Ok, you need to think more conceptually before beginning to apply the equations (by which I mean think about what's going in before just plugging stuff in). For example, in part a- the gravitational potential energy is not mgr, it is mgh (the height of the kid compared with the bottom of the swing isn't equal to the rope length! How do you find this height? Use a bit of trigonometry :). Remember that the mom pulls the swing back 41 degrees). For the kinetic energy at the bottom you're on the right track- you just used an incorrect value for the potential energy, so make sure to correct that. For part c, consider the definition of work- work is the *dot product* of the force and displacement. Why is this relevant? Consider what the dot product between the force (tension) and displacement will always be in this case (think about the angle between the force and the direction in which the kid moves). That's probably enough hints, you can take it from here. Good luck and have fun
Related to Potential and Kinetic Energy on a swing as well as Tension in the rope
1. What is potential energy on a swing?
Potential energy on a swing is the energy that is stored in the system when the swing is at its highest point. This energy is due to the position of the swing at the top of its arc and is converted into kinetic energy as the swing moves downwards.
2. How is kinetic energy related to swinging on a swing?
Kinetic energy is the energy of motion and is related to swinging on a swing because as the swing moves back and forth, it has both potential and kinetic energy. When the swing is at its lowest point, it has the highest amount of kinetic energy, and when it is at its highest point, it has the most potential energy.
3. What factors affect the amount of potential and kinetic energy on a swing?
The amount of potential and kinetic energy on a swing is affected by the mass of the swing, the height of the swing, and the speed at which it is swinging. A heavier swing with a higher starting point and a faster swing will have more potential and kinetic energy.
4. How does tension in the rope affect a swing?
Tension in the rope is what keeps the swing in motion. It is the force that pulls the swing back to its starting point after each swing. The higher the tension in the rope, the faster the swing will move.
5. What is the relationship between potential and kinetic energy and tension in the rope?
The relationship between potential and kinetic energy and tension in the rope is that as the swing moves back and forth, the tension in the rope decreases as potential energy increases and then increases as kinetic energy increases. This cycle repeats as the swing continues to move, and the energy is constantly being converted between potential and kinetic energy.
  • Mechanical Engineering
