- #36
cianfa72
- 2,494
- 268
From a circuit perspective, sure, adding the capacitor C3 is pointless. However my point was to model how things actually work: the battery EMF will "move" electrons away from the terminal that will be the positive to the other terminal that will be the negative one. This process will keep going until the battery inter-terminal intrinsic capacitor will be fully charged at a voltage/PD equals to the battery EMF.Baluncore said:Delete the idea of C3.
Ok, as you pointed out before, the total electrostatic charge will be distributed on the surface of battery's terminals according to the relative effective terminal capacitances and battery EMF -- see Capacitance matrixBaluncore said:Let us assume that during the connection and grounding process, the excess electrostatic charge on the surface of the battery terminals is fixed.
Sorry, by the battery falling towards the ground, you actually mean the process by which the wire attached to the negative terminal is progressively brought closer and closer to the ground until the instant of grounding.Baluncore said:As the flying battery falls towards the ground, the area, a, of the terminals remains constant, while the separation distance, d, between the terminals and ground, is being progressively reduced. The terminal to ground capacitance is proportional to, a / d, so the capacitance is increasing.
The definition of capacitance; c = q / v ;
v = Q / c .
Since the charge is fixed, and the value of capacitance is increasing, the battery terminal voltage will be falling relative to ground.
Ok, yes.Baluncore said:At the instant of grounding, the voltage will reach zero, and the transported excess charge will be dumped, from the battery terminals to the ground.
