Potential energy between two oppositely charged ions in a crystal
The discussion centers on understanding the potential energy between two oppositely charged ions in a crystal. The user, Geoffrey, is confused about how equilibrium can exist despite the attractive forces between the ions. It is clarified that equilibrium occurs when the forces acting on the ions balance out, leading to a net force of zero. The equilibrium point is where the derivative of potential energy with respect to position equals zero, indicating a minimum potential. Visualizing the potential through a graph is recommended to better understand the relationship between the forces and equilibrium.
geoffreythelm
Hi, I am having trouble with the following:
All I have really done is differentiate the function to give an expression for F(r), but I am a bit clueless about the rest. How can there be equilibrium if the two ions are attracted to each other?
Cheers,
GeoffreyThelm
Your potential has two terms, are they both attractive?
I see.. So one (the first term?) is due to the attractive force from one ion, and vice versa for the other? So c is going to end up being something which looks like electric potential should. So is the point of equilibrium the point between the ions where the first term= the second term?
The point of equilibrium is where the sum of the forces is zero. When you have a potential, it is where dU/dx = 0, i.e. where the potential has an extremum (maximum or minimum). In this case it had better be a minimum. Consider plotting this potential to see what it looks like.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
