Potential Energy Function problem ()
The potential-energy function U(x, y) = a*(1/x² + 1/y²) describes a conservative force acting on an object in the xy-plane. To find the force F, the partial derivatives with respect to x and y are taken, resulting in F = [(2a)/(x³)]i + [(2a)/(y³)]j. However, the computer system indicates that the answer should not include the variable "a" and suggests using "alpha" instead. This discrepancy highlights the importance of correctly identifying variables in the problem. The discussion emphasizes the challenges of computer-based grading systems in interpreting mathematical expressions accurately.
ccsmarty
An object moving in the xy-plane is acted on by a conservative force described by the potential-energy function U(x, y)= a*(1 / x^{2}+1 / y^{2}), where a is a positive constant. Derive an expression for the force F expressed in terms of the unit vectors i and j.
Gradient vectors, Partial derivatives
I know I have to take the partial derivatives w.r.t. "x" and "y". But when I did that I came up with F = [(2a)/(x^3)]i + [(2a)/(y^3)]j. But the computer says: "The correct answer does not depend on the variable: a." But if I take the a out, it tells me that: "The correct answer involves the variable alpha, which was not part of your answer."
Any ideas??
Thanks in advance
rename "a" as "alpha" ... maybe "2a" ... ?
^ bump
You aren't being ignored: I think we just aren't sure what the computer doesn't like...
It looks like you've evaluated the gradient of U and expressed the components of F correctly. The issue seems to be what "a" was in the potential function you posted. Is that supposed to be \alpha? Computer entry systems are notoriously finicky. (Curse them!)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
