B Potential energy in standing wave compared to traveling wave
In the discussion on potential energy in standing versus traveling waves, it is noted that elements of a traveling wave at maximum displacement have zero instantaneous velocity and minimum tension, resulting in lower energy compared to other string elements. However, a sinusoidally contoured string, which is longer than a straight string, possesses greater elastic potential energy. The relationship between kinetic and potential energy in standing waves is highlighted, where maximum displacement leads to zero kinetic energy. At nodes, both kinetic and potential energy equal zero, while at antinodes, potential energy reaches its maximum. This analysis illustrates the energy dynamics in both wave types.
versine
TL;DR Summary
Why is the potential energy of a standing wave maximum when the displacement is maximum, but for a traveling wave, it is when the displacement is zero?
From hyperphysics, "The unique point in the case of the traveling wave in the string is the element of the string that is at the maximum displacement as the wave passes. That element has a zero instantaneous velocity perpendicular to the straight string configuration, and as the wave goes "over the hump", it also has minimum tension. So that element of the string has the minimum energy compared to other elements along the sinusoidal contour. This does not imply that a wavelength of the sinusoidally contoured string has less potential energy than the straight string. The sinusoidally contoured string is longer than a wavelength of straight string and will have greater elastic potential energy. As that sinusoidal contour moves along the string, it transports energy. "
Doesn't this also apply to a standing wave since it is a superposition of two traveling waves?
I think for standing waves
kinetic energy + potential energy = f(x) a function depending on the position.
It means when displacement is maximum kinetic energy is zero.
At nodes kinetic energy = potential energy = f(x) = 0. At antinodes f(x) has maximum value.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
