A Potential Energy of Relativistic Particles in Coulomb Field
reterty
Let us consider relativistic particle (electron) which moves with relativistic speed ##v## in the Coulomb field (in the field of a fixed heavy nucleus). The main question is what is the potential energy of a particle in such a static field? Landau and Lifshitz in their book "Field Theory" believe that the potential energy is not renormalized in any way and is equal to ##\frac{qQ}{r}##. At the same time, a number of authors of original articles on this topic introduce a reduced distance ##r\sqrt{1-v^2/c^2}## into the denominator of this fraction due to the relativistic effect of the reduction in linear dimensions. Which of them is right?
I guess you mean the relativistic motion of a charged particle in the coulomb field of a very much heavier particle, neglecting the radiation reaction. The relativistic equation of motion in the non-covariant formalism is derived from the Lagrangian
$$L=-mc^2 \sqrt{1-\dot{\vec{x}}^2} + \frac{q Q}{4 \pi \epsilon_0 |\vec{x}|}.$$
It's of some historical interest since it was Sommerfeld's derivation of the fine structure of the hydrogen-atom spectrum within old quantum theory. It's kind of surprising that he got the correct result although the model is, of course, entirely wrong, i.e., it doesn't take into account the spin 1/2 of the electron and the gyrofactor 2 (both of which weren't known in 1916). That's why you find the solution in Wikipedia here:
https://en.wikipedia.org/wiki/Bohr–Sommerfeld_model#Relativistic_orbit
Likes topsquark, PeroK and malawi_glenn
reterty said:
$r\sqrt{1-v^2/c^2}$
Please note that on this website you need to use a double-$ instead of a single-$ for LaTeX to work.
$$r\sqrt{1-v^2/c^2}$$
Or a double # for inline LaTeX (the double $ means an equation in its own paragraph).
Likes topsquark and vanhees71
For example: https://www.researchgate.net/publication/305345527_A_New_Relativistic_Extension_of_the_Harmonic_Oscillator_Satisfying_an_Isochronicity_Principle
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
