Potential in case of concentric shells
  • Thread starter gracy
  • Tags
    Potential
In summary, a net charge of -q is induced on the inner surface of shell C and this charge is supplied by Earth to shell B. Shell B has a potential due to the net charge on shell A and the charge induced on shell C.
  • #71
gracy said:
yes,there is no charge anymore on the surface
Then why we took this charge -q (supplied by earth) in calculation of net potential of sphere B if there is no net charge on outer surface of shell C?
  • #72
We did not. But there was -q charge on the shell C (on the inner surface) and we calculated with the potential due to it.
Once more: charge has no identity. The charge of shell A pushed q charge into the Earth from shell C, making that shell negatively charged.
  • #73
I think I have got it.There were two questions in my mind while creating this thread
1)net potential of shell B
2)potential of shell B due to induced charge
To calculate these the most important thing we should know is charge distribution
Here charges in red are induced charge and charge in black was already present
This is just for clear understanding of charge distribution.But we know the induced charges on shell B cancel each other and -q (supplied by earth)balances /makes zero induced charge +q on shell C.That's why what we will actually see and the actual charges present are
Net potential is due to all charges present that is charge q shown in black on inner most shell (shell A)and charge -q show in red on inner surface of outermost shell (shellC)
Which we calculated as ##\frac{Kq}{6a}##
And if question asks what is potential due to induced charge? we know -q shown in red on inner surface of shell C is induced charge hence potential due to that will come out to be ##\frac{-kq}{3a}##
We should not get fooled by other red induced charge shown in first picture because those charges are already neutralized and no longer exist.
Am I right?
  • #74
There is still one thing I don't understand that why don't the induced charges on shell c cancel each other as induced charges of shell B do?Why +q on outer surface of shell C is neutralized or balanced by charge coming from Earth and not by -q charge present on inner surface of shell C?
  • #75
Charge has no identity.You can not say why that charge is balanced and not the other.
The -q charge of C (which is there as q charge was pushed into the ground by A ) is distributed as close to the positively charged A shell as possible, that is on the inner surface of C.
Likes gracy
  • #77
One last question
I just want to know why that -q charge stops on inner surface of shell C why it does not go beyond it.I mean if charge -q goes to inner surface of shell B it will be much more closer to +q charge.
  • #78
gracy said:
One last question
I believe the answer is in #12 and #13.There is already -q charge on the inner surface of B and +q on the outer surface, making E=0 in the thickness of B. So, +q responsible for emitting flux lines is actually on the outer surface of B. Hence,
-q on C "stops" as you say, on its inner surface.
  • #79
gracy said:
One last question
Charge is attribute, not entity. Only charged particles can move in the metal shell, (electrons) but they can not leave the metal. They stop at the surface.
Likes gracy
  • #80
gracy said:
One last question
Charge needs a conductive path to follow in order to move unless the field is strong enough to overcome the work-function of the metal and "pull" the charge carriers off of it (electrons in this case), or if enough energy is supplied to the charge carriers for them to escape the surface. See, for example, the photoelectric effect, or thermionic emission.
As ehild has pointed out, In this problem we're considering charge as an attribute and not examining the mechanics of how that attribute is being shuffled around on carriers that have other properties as well (such as mass).
Likes gracy
  • #82
I find one more way to solve this problem.P;lease tell me which one is correct the one in #73 or this one or both?
But we know the induced charges on shell B cancel each other and the induced charges (+q and -q in red on shell C)will also cancel each other and then for the shell C to have zero potential Earth should supply charge -q .And hence there is net charge -q on shell C which has been supplied by earth.
And the same thing as in post #73.But yes one more thing this charge supplied by Earth is also considered as induced charge.
  • #83
It is the same thing as post #73.
If shells B & C were both neutral (no grounding of shell C), then the induced charge is the charge on each surface of those shells.
The grounding of shell C allows the charge on the exterior surface of shell C to be neutralized, so that the induced charge on the exterior of shell C is zero. In this sense, the charge "supplied" by the Earth is included in the induced charge.
