Power Dissipated for 2 different circuits
To determine the ratio of R1 to R2 for equal power dissipation in circuits A and B, the currents through R2 must be set equal, leading to the equation (2EMF)/(2R1+R2) = (EMF)/[(R1^2/2R1) + R2]. The discussion highlights uncertainty about simplifying the equation by removing EMF, which is indeed constant. For part B, the condition under which power dissipated in circuit A exceeds that in circuit B is debated, with R2 > R1 being a proposed solution. Participants express confusion regarding calculations and seek confirmation on their findings, particularly when substituting values for R2.
lowcard2
Part A:
For what ratio of R1 and R2 would power dissipated by the resistor of resistance R2 be the same for circuit A and circuit B?
current for R2 of circuit A is (2EMF)/(2R1+R2)
current for R2 of circuit B is (EMF)/[(R1^2/2R1) + R2)
Part B:
Under which of the following conditions would power dissipated by the resistance in circuit A be bigger than that of circuit B? Choose the most restrictive answer.
R2<R1
R2>R1
R2<2R1
R2<.5R1
Equations used:
P = IV = I^2 x R = V^2 /R
Attempt:
I understand since R and P is same for both i only have to make the 2 currents equal.
(2EMF)/(2R1+R2) = (EMF)/[(R1^2/2R1) + R2)
I haven't taken physics or math class in 2 years so I'm kinda unsure on how to continue.
Since EMF is constant can I just remove it?
For part B just by plugging in numbers R2>R1 works but I am not certain
Diagram please.
totally forgot but here it is
deleting my post
if i can take out EMF and make R2 = 1 i come out with 4 as my answer. can anyone confirm?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
