Power & Force: Solving a Cyclist's Problem
  • Thread starter Thread starter 7tongc5
    Force Power
The discussion centers on understanding the relationship between power and force in the context of a cyclist's performance. A cyclist is moving at 8 m/s with a power output of 500W, and the main inquiry is about calculating the force exerted on the pedals. Clarification is provided that the force required to propel the bike forward may differ from the force applied to the pedals. The conversation emphasizes the importance of distinguishing between these two forces when solving the problem. Understanding this distinction is crucial for accurately applying physics concepts to real-world scenarios.
7tongc5
Hi
just took my physics test today and it turns out that the 2 problems i couldn't get both happened to test my understanding of the relation between power and force. I don't have numbers but i'd like to get a better understanding of that concept so.. here's the gist of it:
There's a cyclist moving at 8 m/s w/ 500W. Find the force used to push down the pedal.
something like that. Any little hint would be appreciated! Thanks
Are you sure that the problem asked for the force used to push down the pedal? The reason I ask is that the given information is sufficient to tell you the force with which the bike is propelled forward, but that is not necessarily the same as the force applied to the pedal.
if not the force applied to the pedal, then it's probably the force that propels the bike forward.
*I don't remember the exact wording, but i;m sure of the info that was given.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
