B Power from global loop power cable ?
A power transmission line forming a loop around the equator could potentially harness energy from the Earth's magnetic field, although it may not be economically viable. Circumnavigating the Arctic Circle might also yield useful power, influenced by magnetic storms and ionospheric currents. However, regulating voltage and current presents significant challenges. The Earth's magnetic field variations would largely cancel out due to its consistent direction above and below the loop. An alternative idea includes creating an East-West tunnel to capture magnetic field variations more effectively.
synch
Just a thought ... Given that the earths magnetic field has a stream of small changes, would a power transmission line forming a loop around the equator generate useful power ? Not exactly economic of course. Maybe just circumnavigating the arctic circle would be enough ?
Magnetic storms with ionospheric currents would dominate the loop output. One big problem would be in regulating the voltage and current.
Since the Earth's field passes in the same direction, both above and below the loop, most of the field variation would cancel.
Maybe find an East-West tunnel through a hill, then wind a loop through the tunnel and over the hill. That will pick up variations in the Earth's field.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
