Power Law Equation Help: Solving for v with x=0.02 | Homework Equations
Adam_9333
need to solve for v? I also know the value of x=0.02
v(x)= 47.8 ⋅ (0.451/x)^(5.39)
how do I take the log of both sides, is that the right approach to solve for v?
Apply the product rule then the power rule.
Likes Adam_9333
But, if you already know x, you don't have anything to solve. Just put .02 in for x and evaluate.
I am little confused, my calculus skills stayed in first year. Do put 0.02 in the x term on the left side of the equation also, and just solve for V?
You didn't state the problem accurately, but if it's asking you to determine v(0.02), then all you have to do is to replace the x on the right by 0.02 and perform the computations. To "solve for v" would be to find an equivalent equation with v alone on one side, but the equation is already of that form, so what you need to do to solve for v is nothing at all.
That would be a good approach if you wanted to solve for x.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
