Power Loss in transmission lines: Which method is correct?
The discussion centers on two methods for calculating power loss in transmission lines, with conflicting results. Method 1 calculates a power loss of 0.16W, while Method 2 suggests a loss of 25W. Participants note that the problem statement may be overly constrained by specifying an output voltage of 10V, which could lead to inaccuracies. The correct approach involves starting with the input voltage and output current to determine the actual transformed output voltage. Ultimately, the consensus is that Method 1 is more reliable, as it aligns better with the principles of circuit analysis.
PaulK
Here is the problem:
http://postimage.org/image/1jy6nol5w/
Method 1:
Steps
1. Calculate V(T1)=12*10=120V,
V(T2)=10*10=100V
2. Since V(3)=10V and I(3)=1A, P(T3)=10W
3. Since not otherwise stated, Assume transformers are perfect.
4. So P(T3)= P(T2) = 10W
5. known P(T2)=10w and V(T2) =100V, Calculate: I(T2)= 10/100 = 0.1 A
6. Since resistors are connected in series, Current through each resistor = 0.1A
7. Power Loss = (0.1)^2 * R = 0.001 * 16 = 0.16WMethod 2.
V(T2)=10*10=100V
2. Voltage consume by resistors = V(T1)- V(T2) = 120 -100 =20V
3. Power loss = (20)^2 /16 = 25W
Both method seem to make sense, but of course only one of the is right (Or none?)
Please tell me which one is wrong and why.
Thanks a lot.
Method 1:
Steps
V(T2)=10*10=100V
Method 2.
V(T2)=10*10=100V
Thanks a lot.
I think there is an error in the problem statement. They are over-constraining the problem by giving you an output voltage of 10V.
Start with the input voltage and output current (like in your First Method). The output current defines the TL current of 0.1A, which defines the voltage drops across the TL resistors. The input voltage and the TL voltage drops define the transformed output voltage. What do you get for the transformed output voltage? Not 10V.
It is such a relief. Thanks a lot, berkeman.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
