Power plants alternating emf is generated by rotating
In power plants, alternating EMF is generated by a rotating loop in a magnetic field, proportional to the turbine's angular velocity, which affects frequency rather than output EMF. Maintaining a constant angular velocity is challenging, especially in hydro power plants, but large machines with high inertia provide stability. When connected to a grid, the frequency remains stable as multiple generators share the load, while standalone plants may experience frequency drops if demand exceeds supply. Turbines utilize governors to adjust energy input based on load fluctuations, with larger turbines typically serving as base load and smaller gas turbines acting as peaking units for rapid response. Overall, effective regulation mechanisms ensure consistent power supply despite variable demand.
prudhvi mohan
In power plants alternating emf is generated by rotating loop in magnetic field which is directly proportional to angular velocity of turbine.I think it is highly impossible to maintain angular velocity of turbine constant(especially in hydro power plants).Then how are they supplying a constant rated current?
The EMF generated is independent of the turbine speed, all that turbine speed gives is frequency.
but then how output frequency is held constant ?
The grids constant frequency keeps turbine speed constant independent of torque on the tubine. 1000+ other generators share the same load and thus keeps a stable frequency.
If the power plant is not connected to a "infinite bus/grid" but operating alone, the frequency will drop if demanded real power exceeds supplied power.
Keeping a constant angular velocity (within acceptable limits) isn't that hard, big machines with large inertia is pretty stable. Small machines with less inertia can for a few seconds have a speed drop if a sudden power demand is connected. Hydro electric plants are ideal for this, since they can regulate the governor setpoint pretty fast, steam turbines on the other hand have slower regulator speed.
Turbines have governors to adjust the input of energy/torque according to the load.
Large turbines are usually base loaded on a grid, which as smaller gas turbines are used as peaking units because they are ramped up quickly in response to increased load.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
