Power, Rpm, Torque - Horsepower increase for my small engine
In summary: The current setup, which has a centrifugal clutch and two sprockets, is not powerful enough for my needs. The main factors affecting engine power are brake mean effective pressure, mean piston speed, total bore area, and volumetric efficiency. Doubling any of these factors will double the power, but since stroke and bore cannot be changed, the best options are increasing BMEP through fuel or oxygen, increasing mean piston speed at the cost of reliability, and improving volumetric efficiency through turbo
ThinkR
Hello all, the short story is, I am basically trying to get the same ( or a little more) “power” out of a larger lawn mower type gas engine ( vertical shaft) as one of the largest (120 ish cc) chainsaws ( ref the Stihl MS 880 or newer 881 at approx 10-12k rpm and 9 Hp)
The parameters are : a relatively small form and weight as close to that of the chainsaw as feasible. (but I realize at least double is likely). With off the shelf parts for the most part. I have already built an aluminum “power plate” to hold such a motor and trans which simply has 2 bearings and 5/8” shafts to transfer the power with a centrifugal clutch on the motor side with an approx 2 inch sprocket and an approx 8” sprocket on the driven side. It does not have enough “ power” to drive my machine. TIA to all who participate.
The engine power is directly related to:
  • Brake Mean Effective Pressure (BMEP)
  • Mean piston speed (= RPM X Stroke)
  • Total Bore area (= piston bore area X number of pistons)
  • Volumetric efficiency
Double any of those (without altering the others) and you will double your power. Or increase each of them by 19% and you will also double the power.
Stroke and bore seem to be what you don't want to change so this leaves:
  • BMEP: Doubling it is very unlikely. Your best bet is changing the fuel and/or adding oxygen (i.e. injecting nitrous).
  • Mean piston speed (through the RPM): Doubling it is very unlikely because it is usually optimized for power vs reliability. But if you can accept losing reliability, you might get some room here.
  • Volumetric efficiency: Probably your best bet overall. It is usually done with force induction (turbo or supercharger). But if your engine intake and exhaust systems are not already tuned, redesigning them would make a big difference without any reliability consequences.
Increasing each of these three things by 26% will also double your power.
Except for intake & exhaust systems tuning, any modification will most likely require stronger components (piston, connecting rod, crankshaft, etc.) for great power increases, or at least machining with tight tolerances (blueprinting).
Likes ThinkR and berkeman
Wow. Great response. Thank you.
Likes jack action
I guess what I am asking is, for those who really know the math, will the 16hp John Deere be able to make a little more power ( however calculated) than the Stihl Ms 880 chainsaw without major modifications or is there another powerplant out there that will do the job. What I am trying to avoid is the cost ($2000) and noise of the big chainsaw.
If you have a 16hp John Deere, it’s already about double the stock HP of that chainsaw?
Likes jack action
FAQ: Power, Rpm, Torque - Horsepower increase for my small engine
What is the relationship between power, RPM, and torque in an engine?
Power, RPM, and torque are interrelated in an engine. Power (measured in horsepower) is a function of torque (measured in pound-feet or Newton-meters) and RPM (revolutions per minute). The formula to calculate horsepower is: Horsepower = (Torque x RPM) / 5252. This means that for a given amount of torque, increasing the RPM will increase the horsepower.
How can I increase the horsepower of my small engine?
To increase the horsepower of a small engine, you can make several modifications: upgrade the air intake and exhaust systems to allow for better airflow, use a higher octane fuel, install a performance camshaft, and optimize the engine's tuning. Each of these changes can help the engine run more efficiently and produce more power.
What role does torque play in engine performance?
Torque is a measure of the rotational force the engine produces. It is crucial for activities that require substantial pulling or pushing power, such as towing or accelerating from a stop. Higher torque at lower RPMs can make an engine feel more powerful and responsive in everyday driving conditions.
Why is RPM important for engine performance?
RPM, or revolutions per minute, measures how fast the engine's crankshaft is spinning. Higher RPMs can lead to higher horsepower because the engine can complete more power cycles in a given time. However, running an engine at very high RPMs for extended periods can cause wear and tear, so it's essential to balance RPM with engine durability.
What are some common upgrades to increase torque in a small engine?
Common upgrades to increase torque in a small engine include installing a performance camshaft, upgrading the carburetor or fuel injection system, using a high-flow exhaust system, and increasing the engine's displacement. These modifications can help the engine produce more torque, especially at lower RPMs, improving overall performance.
