Power System, synchronous generator
In summary, a synchronous generator is a device that converts mechanical energy into electrical energy and is commonly used in power systems. It works by using a magnetic field to induce an electrical current in a wire and has main components such as the rotor, stator, exciter, prime mover, and governor. Compared to an asynchronous generator, it produces electricity at a fixed frequency and requires an external power source to maintain its magnetic field. Some advantages of using a synchronous generator include its ability to maintain a constant frequency and voltage, high efficiency, and ease of synchronization with other generators. Its simple and robust design also makes it a reliable choice for power generation.
LagCompensator
24
Sorry for bad title(little informative regarding my question), however I came across the following question given as an exam question at some university.
Question:
"A synchronous generator is running overexcited with excitation voltage Ef = 1.40 p.u and connected to the network at voltage of 1 p.u. This generator has synchronous reactance of 1.20 p.u., and delivering active power of 0.50 p.u. to the network. In the network, there is 1% increase in real power due to power drop from uncontrolled network connected renewable power source. Therefore, the prime mover (i.e. turbine) input is increased by 1%. The excitation or voltage controller of synchronous generator is not responding to this change. Explain how the reactive power delivery from the synchronous generator will change under this condition"
So, the Q delivered by the generator per phase is:
[itex]Q = \frac{E_fV_t}{X_d}cos(\delta)-\frac{V_{t}^{2}}{X_d}-V_{t}^{2}(\frac{1}{X_d}-\frac{1}{X_q})sin^2(\delta)[/itex] (1)
So according to this equation the Q will not change due to increase in turbine input.
However if we take a look at this equation:
[itex]P = \frac{E_fV_t}{X_d}sin(\delta)-\frac{V_{t}^{2}}{X_d}-V_{t}^{2}(\frac{1}{X_d}-\frac{1}{X_q})sin(2\delta)[/itex] (2)
An increase of P will cause an increase in [itex]V_t[/itex], and an increase of [itex]V_t[/itex] will increase the reactive power delivered by the sync. generator according to equation (1)
Can someone tell me if this is the right way of thinking or if I am missing something please tell me.
Best Regards
later after I've checked my phasor arithmetic...
seems to me Vt is fixed by network at 1.0 and this is a (Vexc-Vnetwork)/jXs question.
You're given the real component before and after.
@LagCompensator
I'll take a stab at this.
Being not a power system guy it'll be amateurish
but i hope logical.
As textbooks and teaching methods evolve, some things become so refined that we lose track of the lower parts of the learning curve.
LagCompensator said:
Question:
Okay , a picture might help us grunt this one out from the basics... I think in pictures not formulas.
Here's how i envision that circuit.
Circle at bottom is phasor diagram,
since we don't know power angle of the machine (angle of Ef) i just drew Ef some arbitrary place on a circle with radius 1.4.
What do we know ?
Vnetwork i assumed infinite bus since they gave us no network impedance value.
I gave it value 1∠0 so it'll be our reference for phasor diagram. Polar for 1∠0 is 1+j0 .
We know that Iline has real component 0.5 because power is 0.5 .
So it'll have imaginary component jVars.
I'll assume lagging current, so that'll be -jVars. If I'm wrong we'll just get a negative Var current. Iline = 0.5 -jVars
Ohm's law tells us voltage across Zline is Iline X Zline.
Kirchoff's voltage law tells us that
Vnetwork + Iline X Zline = Vf
but we have a lot of unknown angles...
Let's plug in what we know
1+j0 + (0.5 -jVars) X (j1.2) = 1.4∠unknown
1 +j0.6 +1.2XVars = 1.4∠unknown
Aha !
Look back at the phasor diagram
we have a right triangle with adjacent side (1.0 + 1.2XVars) volts, opposite side 0.6 volts, hypotenuse 1.4 volts and no angles known.
Pythagoras let's us find adjacent side
(1.0 +1.2XVars) = √(1.42 - 0.62)
1.2 X Vars = 1.265 -1
so Vars = (1.265 - 1) / 1.2 = 0.2207
Repeating for real component of Iline = 0.51 i get 0.2159
That's the simplistic approach i'd use. If we worked numerous problems a shortcut would probably show its head..
Maybe some kind soul will improve(or correct) my explanation...
Likes cnh1995
Thank you, i'll take a closer look once I get home from work.
FAQ: Power System, synchronous generator
What is a synchronous generator?
A synchronous generator is a device that converts mechanical energy into electrical energy. It is commonly used in power systems to generate electricity.
How does a synchronous generator work?
A synchronous generator works by using a magnetic field to induce an electrical current in a wire. The magnetic field is created by rotating a coil of wire, called the rotor, inside a stationary magnetic field, called the stator.
What are the main components of a synchronous generator?
The main components of a synchronous generator include the rotor, stator, exciter, prime mover, and governor. The rotor is the rotating part that creates the magnetic field, while the stator is the stationary part that carries the electrical current. The exciter provides the necessary DC field current to the rotor, and the prime mover is responsible for turning the rotor. The governor controls the speed of the prime mover to maintain a constant frequency.
What is the difference between a synchronous and asynchronous generator?
A synchronous generator produces electricity at a fixed frequency, while an asynchronous generator can produce electricity at varying frequencies. Additionally, a synchronous generator requires an external power source, such as a prime mover, to maintain its magnetic field, while an asynchronous generator does not.
What are the advantages of using a synchronous generator?
Some advantages of using a synchronous generator include its ability to maintain a constant frequency and voltage, its high efficiency, and its ability to easily synchronize with other generators in a power system. It also has a simple and robust design, making it a reliable choice for power generation.
