Preserving data with a new OS install
  • Thread starter Thread starter Eakkoy
    Data install Os
To unlock a locked laptop and recover data, removing the hard disk and connecting it to another device as an external drive is a common approach. This can be done using a hard disk kit that allows USB connection. However, caution is advised as some operating systems may encrypt the hard disk, complicating data extraction without the proper encryption keys. Knoppix is suggested as a tool to access drives with read issues. It's important to note that hard disk encryption is optional and not enabled by default on Windows 10. If there are no disk errors, creating a backup disk image before proceeding is recommended. Additionally, tools like Cain & Abel may be considered for further assistance in unlocking the laptop.
Eakkoy
This is a locked laptop,in order for it to work again,i need to install a new OS , i am going to remove the hard disk of the computer and extract data on other devices. My friend told me that this is ok, but I am worried that the data saved on the hard disk of the computer will be lost.
Maybe there is a safer and easier method.
Computer science news on Phys.org
Often people will remove a hard disk and make it an external drive using a kit. From there, you can use USB to connect it to your newer computer and extract files as needed.
https://www.amazon.com/dp/B00UAA4J6G/?tag=pfamazon01-20
However, be aware that some OSes encrypt hard disks making it difficult to impossible to extract your files without the encryption methodology and key.
Knoppix is often used to access drives that have some read issue so you could check that out.
https://www.knopper.net/knoppix/index-en.html
Likes davenn
Hard disk encryption is optional and up to the user to decide, and the OS doesn't do it by default. At least that's how it is on Windows 10 (and other versions), don't know about other OS's.
Likes davenn
If it is not some disk error then you can try making a backup disk image first.
Worst case this will be the same size as the disk itself so better do this directly, by attaching the disk as real disk and not through any USB...
I went on a 5-day business trip,when i got home yesterday, i turned on my computer, but it was still locked,it is Windows 10,and this locked laptop hasn't worked for a week,and my colleague recommended Cain & Abel, which is free.Maybe i should try.
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
I've been having problems for the past few weeks with the display on my Dell computer. I bought the computer new back in 2019 or so, which makes it about 6 years old. My monitor is a 27" HP monitor that I bought for another computer (an HP Pavilion), recently demised, back in about 2012 or 2013. As far as I can tell, the computer, which is running a 10-core Xeon Scalable processor, is functioning as it should. The first symptom was that the screen would go dark, which I would attempt to...
