Preserving local realism in the EPR experiment
In summary, the idea that the spooky correlation in the EPR experiment is simply due to the initial difference in rotation between the two polarizers is flawed because the polarizer directions can be chosen just before each measurement in a way that prevents any information from one polarizer affecting the other measurement. Additionally, the polarizers do not necessarily have to physically rotate in order to change their orientation.
  • #36
Mentz114 said:
Isn't it sufficient to project the second measured photon ( say B) into the angle of A's polarizer if A gets a hit ?
If A gets a hit, we know its angle. But how does B know if A got a hit? :rolleyes:
  • #37
B does not need to know that. The paired photon may have changed state after the first measurement. That is what entanglement is supposed to mean.
In the simulation that is the only thing that differs from a random setup.
  • #38
Well, in the usual setup the measurement of B doesn't do anything on A. To ensure this you make the measurement acts spacelike separated. That's what's so mind boggling about these stronger-than-classically-possible correlations described by an almost trivial math. As easy is the math as mind boggling are the implications, particularly if you stick to traditional collapse assumptions of the early days! The worrying immediately stops if you simply accept that nature is inherently probabilistic and that there is a very successful formalism called QT that tells you probabilities and only probabilities.
  • #39
vanhees71 said:
Of course, you have to precisly simulate the probabilities given for the assumed experimental setup. Of course, I have to use the relative angle of the detectors to calculate these probabilities, and thus this information goes into the code.
But the relative angle is not known until the last minute. The situation is the following:
You have three devices: C, which is a source of message pairs, simulating photon pair production, and A and B, which simulate the measurement events.
  • Every "round", C sends out a pair of messages, [itex]m_A[/itex] to A and [itex]m_B[/itex] to B.
  • After the messages are sent, but before they are read, settings for A and B are chosen, independently. The settings are two angles, [itex]\theta_A[/itex] and [itex]\theta_B[/itex].
  • Device A determines an output, [itex]R_A(\theta_A)[/itex], which is either +1 or -1, based on the message received from C and the setting [itex]\theta_A[/itex].
  • Similarly, device B determines an output, [itex]R_B(\theta_B)[/itex] based on its message and setting.
  • Over many, many rounds, we can gather statistics for the correlation: [itex]\langle R_A(\theta_A) R_B(\theta_B) \rangle[/itex] as a function of the pair of settings, [itex]\theta_A, \theta_B[/itex].
Bell's inequality implies that [itex]|\langle R_A(\theta_A) R_B(\theta_B) \rangle| \leq 2[/itex], no matter what algorithms are used by A, B, and C, as long as
  1. There are no communications among A, B, C other than those specified.
  2. The settings [itex]\theta_A[/itex] and [itex]\theta_B[/itex] for each round are unpredictable by C.
On the other hand, if instead of C sending messages, it generates a pair of entangled photons, and sends one to A and one to B, then you can violate the inequality. (Inside A and B, instead of a computer algorithm, you have polarizing filters and photon detectors, and each sends out +1 if the photon passes through the filter at the orientation specified by [itex]\theta_A[/itex] or [itex]\theta_B[/itex].
Likes kurt101
  • #40
Because, in a computer, this would have to be a HV-setup, it would not reproduce the desired result.
  • #41
I don't know if this is addressed to me but - I'm not worried nor ever have been by any of the great 'problems' in QT !
Like you I believe if we can calculate probabilities we can simulate any experiment.
Entanglement changes the probabilities a lot and it is easy enought to show this.
My first run of 400 produced these quartets (count, coincidences, ##\chi^2## contribution, expected value = count/2 )
A1B1=( 105, 48, 0.38, 52.5)
A1B2=( 103, 25, 13,2, 51.5)
A2B1=( 100, 77, 14.5, 50)
A2B2=( 92, 56, 2.17, 46)
The sum of the ##\chi^2## terms is 30.5 which is in the very small percentile of the ##\chi^2## distribution with 3 dof.
Clearly allowing the first projection to set both photons has skewed the probabilities drastically compared to the unentangled set up.
  • #42
Sure, I'm aware of this, but no matter when you choose the orientation (even in the last femtosecond before the envisaged photon hits the detector) you know the probabilities you have to simulate, when using this setup to calculate the corresponding probabilities (or expectation values). The probabilities are known of course; it's what's predicted by QT, and that's what's simulated with a correspondingly programmed MC simulator.
Likes Mentz114
  • #43
I'm not exactly sure what your point is. Yes, we know the probabilities for joint detection. The question is whether you can simulate the detection process in the way that I have sketched out and get those probabilities. The answer is "no".
When you choose the orientation makes a difference, because if the orientation was planned in advance, then device C could use that information to reproduce the predictions of QM.
  • #44
I don't really know what you (@vanhees71) mean by a "Monte Carlo" simulation for this experiment, but the only way you can reproduce the predictions of quantum mechanics for this case is if the settings for the detectors are known by the simulation code. In other words, by cheating (according to the rules laid out).
Likes DrChinese
  • #45
https://en.wikipedia.org/wiki/Monte_Carlo_method
  • #47
As mentioned in post #25: you cannot simulate entanglement if Alice doesn't know Bob's choice of measurement setting, and Bob doesn't know Alice's choice of measurement setting. So yes, if you circumvent that, you "cheat". That is to say that using the relative angle in the code to generate the answer is a cheat. If you don't cheat, you can't even hand pick data sets that match the probability predictions of QM.
So hopefully we are all in agreement on this point, which was what was in error in the OP's original code - which made use of the relative angle.
Likes entropy1
  • #48
Isn't it enough if "Charlie" (or "C") knows both measurement settings as said by @stevendaryl in post #43 ?
  • #49
The measurement settings are not fixed in principle; they can be changed at the last moment.
  • #50
I know that - are you saying that I can't simulate entanglement without changing measurement settings at the last moment ?
  • #51
The principle is that the settings are unknown (till the last moment). If they are fixed and conveyed (to C) we have a special case IMHO.
  • #52
stevendaryl said:
But in a Monte Carlo simulation, the inputs are generated, as well as the outputs, which means that the inputs (the detector settings, in this case) are known in advance.
This is hard to explain because I cannot see the problem. We know that A and B will have definate settings before they project their photon. It does not matter when they get them as long as the selection is random (independent).
The simulation works stepwise. Produce a random orientation ##\theta_0## ( 1 random used ). Now assume that A's photon reaches the polarizer set to ##\theta_A##. The probability of passing we know is ##\cos(\theta_A-\theta_0)^2##. Now draw another RN to see if it passes.
If it passes we can say the alignment of photon B is ##\theta_A## and now we can calculate if it will pass B's polarizer which depends on B's setting.
It works. Statistically the results are obviously violating the expectations.
  • #53
If your algorithm for determining the result of A's measurement requires knowledge of B's setting, or if you need to know A's setting to determine B's results: then you are not using a separable algorithm. Thus the "cheat" and it is not simulating local realism. If you allow the "cheat", you CAN simulate QM/entanglement. But that is the only way.
Likes forcefield, PeterDonis and entropy1
  • #54
If passes we can say the alignment of photon B is ##\theta_A## and now we can calculate if it will pass B's polarizer.
It works.
This would simulate QM entanglement, because of your usage of ##\theta_A## to calculate B's outcome. Without that information, you can't get agreement with the predictions of QM. So if the A and B algorithms are separate, per Bell you can't get that agreement.
Likes Mentz114
  • #55
Yep. It is possible to simulate entanglement. Only the (simulated) projection of both photons is required to do this. A's setting is not 'known' by B - it is carried by the photon and affects B's result.
Likes DrChinese
  • #56
If the wavefunction (which is what you mean, I think) is transporting information from A to B, wouldn't we have manifest non-locality?
  • #57
entropy1 said:
If the wavefunction (what is what you mean, I think) is transporting information from A to B, wouldn't we have manifest non-locality?
When either of the photons is projected into a definate polarization state the other must also be in that state. Experiments seem to show that the separation is irrelevant. So information has gone from the first projected photon to the other ( it is said ) but I think they are just always are in the same state - a shared field.
  • #58
Mentz114 said:
When either of the photons is projected into a definate polarization state the other must also be in that state. Experiments seem to show that the separation is irrelevant. So infoemation has gone from the first projected photon to the other.
I am not so sure myself; there is no temporal ordening of the detections; A is not before B, nor B before A in a spacelike separated setting. So there is no 'transporting' in any definite direction.
Likes Mentz114 and DrChinese
  • #59
In the simulation, you can do it as you like (A before B or whatever). It is interesting that in real life, as you say, there is no apparent definite direction. And the predictions are the same regardless of which measurement occurs first.
Likes Mentz114 and entropy1
  • #60
I don't know exactly what it is that you are describing here. This is the answer to what question?
  • #61
Another cheat is to allow post-selection or flexible coincidence matching, like in https://arxiv.org/abs/0712.3693
Likes kurt101
  • #62
This statement
I take to be an objection of some kind. But it does not make sense in the context of a MC simulation. I respectfully suggest that you try to understand how the MC works.
To simulate a coin toss we can draw a random number in the range [0,1]. If we simulated a lot of coin tosses the results would be indistinguishable from a real experiment providing we have quality RNs. If we have have a process where a later event depends on the value of a random variate then the joint distribution of the first and second variates can be generated in this way.
(I'm trying to do it analytically but it's very hard)
I understand the impossibility of doing a space-time/dynamic simulation of the experiment. We only have probabilities so this would be a non-starter anyway.
Likes vanhees71
  • #63
I guess I don't understand why Monte Carlo simulations are relevant [edit: to this thread]. Of course, we can simulate the probabilistic predictions of quantum mechanics. What we can't do, as implied by Bell's inequality, is simulate it in a way that respects the causal relationships between the parts, namely,
  • there are no signals propagating between the two detectors
  • there are no signals propagating back from the detectors to the source
  • the detector settings are unpredictable
  • #64
stevendaryl said:
I guess I don't understand why Monte Carlo simulations are relevant. Of course, we can simulate the probabilistic predictions of quantum mechanics. What we can't do, as implied by Bell's inequality, is simulate it in a way that respects the causal relationships between the parts, namely,
The first two things you've listed belong in space-time and dynamic simulations. The third is a about probability and is respected in the simulation.
The probabilites used are these [ which I think are correct, but I could be wrong]
##P_{11} = {\cos\left(( \theta_A-\theta_0\right)/2) }^{2}\,{\cos\left(( \theta_A-\theta_B\right)/2) }^{2}##
##P_{10} = {\cos\left( (\theta_A-\theta_0)/2\right) }^{2}\,{\sin\left( (\theta_A-\theta_B)/2\right) }^{2}##
##P_{01} = {\sin\left(( \theta_A-\theta_0)/2\right) }^{2}\,{\cos\left( (\theta_0-\theta_B)/2\right) }^{2}##
##P_{00} = {\sin\left( (\theta_A-\theta_0)/2\right) }^{2}\,{\sin\left(( \theta_0-\theta_B)/2\right) }^{2}##
which sum to 1. ##\theta_0## is a random variable uniform in the range ##[0,2\pi)##, ## \theta_A## and ##\theta_B## are random variates with two equal probability values.
The presence of ##\theta_A## in the second terms of the first two probabilities reflects the fact that the entangled pair always have the same polarization angle. So if A has projected their photon, B's photon must have the same value.
  • #65
Of course, the settings of the detectors have to be known by the simulation code and also in the real experiment to be able to analyze it. That's in the very foundations of QT, and that's at the heart of all these interpretation issues: You need to know both the prepared quantum state and the setup of the experiment (i.e., knowledge about what's measured) to get the probabilities according to Born's rule, no matter when you choose the setup of the measurement devices (often also using a random choice in post-selection mode, but of course, to test QT you need to know which choice has been made in the coincidence measurements to be able to analyze the experiment in comparison to QT, i.e., the measurement protocol must contain for each event the randomly chosen orientation of the polarizers and the like).
  • #66
I really don't understand the point that is being made. In an actual EPR experiment, it is not necessary to know the two settings of the detectors ahead of time. The setting choices can be made at the last moment, using independent means. For comparison with QM, it's only necessary to record the settings afterward.
  • #67
entropy1 said:
Do you have locality then?
You mean in an actual QM EPR experiment? I don't know. There is certainly no possibility of FTL communication, so by that definition, it's local.
  • #68
Sorry, I mixed your name up with Mentz's. :oops:
  • #69
This business of the settings being 'known' or not is irrelevant. When a photon interacts with a polarizer the only things that matter are the 1) photons polarization and 2) the polarizer angle at that time. To do the simulation only those quantities can and must be used. In a real experiment it is the same. The photon knows nothing, we know nothing but those things have a value.
  • #70
But you don't need to know the photon's polarization in an actual EPR experiment. That's a hidden variable, which Bell's theorem rules out.
If you want to assume a "collapse" interpretation, then I guess you could reason that the photons are unpolarized (or have a random polarization) before being measured, but after one photon is measured, the other photon changes state to be polarized the same as the first. But that's a nonlocal interpretation. The topic is "Preserving local realism".
Likes kurt101
12K
