Pressure and Temperature and Heat
An ideal gas problem involves calculating pressure changes when volume changes at constant temperature, using the ideal gas law. The second problem applies the first law of thermodynamics to determine the change in internal energy after heat is added and work is done. A third scenario requires finding the specific heat capacity of a metal after thermal interaction with water. Clarifications on the ideal gas equation emphasize that the number of molecules remains constant, simplifying calculations. Understanding these principles is crucial for solving thermodynamic problems effectively.
omgitsmonica
An ideal gas occupies a volume of 0.3 m3 at the pressure of 400 kPa. If the volume changes to 0.85 m3 and the temperature remains constant, what is the pressure of the gas? Give answer in kPa.
OR
If 500 cal of heat are added to a gas, and the gas expands doing 394 J of work on its surroundings, what is the change in the internal energy of the gas in Joules.
OR
150 g of a certain metal, initially at 100o C is dropped into an insulated beaker containing 100 g of water at 20o C. The final temperature of the metal and water in the beaker is measured at 43o C. What is the specific heat capacity of the metal in cal/(g o C)?
W = P*deltaV
Q = mcdeltaT
I have no idea what's going on with any of these problems... if anyone can help me I would be awesomely grateful.
For the first question you need to use the ideal gas equation: PV=nRT
For the second, you need to use the first law of thermodynamics: dq = dU + dW where dW is the work done by the system.
AM
THANK YOU THANK YOU THANK YOU.
Just one question, and then I'll do the work on my own, I promise -- for the ideal gas equation, where N determines the number of molecules, how do I figure out how many molecules there are?
Okay, so, for the second one, I looked through my textbook and found the equation PV=(2/3)K. I tried using that equation (because it doesn't consider temperature or N) but I came up with a ridiculously low number. Is that right, or am I completely off base?
You don't need to calculate n. You just need to know that it does not change. So if T does not change, what can you say about the product PV? Does it change?
AM
No, then it doesn't. So if nRT is constant, the two PVs should be the same.
Thank you so so much for all your help.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
