Pressure Cooker Internal Energy Problem
The discussion revolves around the energy dynamics in a pressure cooker, which is a nearly airtight system. It involves 15,000 J of energy used to vaporize water, with 4,000 J leaking to the atmosphere, resulting in a net energy gain of 11,000 J. The participants explore different thermodynamic processes, noting that isovolumetric, isothermal, adiabatic, and isolated processes do not accurately describe the situation due to energy exchange with the surroundings. The conclusion highlights that the pressure can increase without work being done on the system. Understanding these energy exchanges is crucial for analyzing the internal energy changes in such systems.
sharpnova
A pressure cooker is a nearly air tight sealed system. When seated on a stove burner and heated, water turns to steam and increases the pressure inside, resulting in higher temperatures so food cooks faster. Suppose 1/2 cup of water is inside the pressure cooker and it is on an active burner on the stove. Suppose that 15000 J of energy vaporize the water and that 4000 J leak out of the system to the atmosphere. What is the name of this kind of process? How much energy is exchanged by heat? Is the energy put in or taken out of the system? How much energy is exchanged by work? Is that work done by or on the system? What is the change in the system's internal energy? (give the sigh of that change as well as the amount)
change in internal energy = heat added + work done by system
For the first question (identifying the type of process) I can't find one that satisfies the situation.
Isovolumetric has the work done by the system as zero. But the system does work on the gas (increasing its pressure)
Isothermal has the change of internal energy as zero. But the system takes in 15000 J and leaks out 4000 J so there is an 11000 J difference.
Adiabatic has the the condition "no heat in or out" but 15000 went in and 4000 went out for a net of 11000 in.
Isolated has no interaction with surroundings but since 4000 J leak out it is interacting with its surroundings.
It is possible for the pressure of a system to increase without any work being done on the system.
Thank you that cleared it up for me
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
