some bloke
- 279
- 98
Hello all, I'm new to this forum and I'm mucking about with some self-made physics conundrums, and I need some help!
So, What I am aiming for is a roughly cylindrical vessel (it can, and I think probably has to, be tapered to achieve the effect) with the air being pumped out of one end, and a valve offering a controlled amount of resistance at the other end to create a partial vacuum. The valve can be opened to a point where the air flows freely through the pipe and the pressure difference from outside is negligible.
What I want to achieve is for the pressure, compared with the ambient pressure around the vessel, to be different at one end of the pipe to the other.
I know that "sucking" isn't a thing, it's the pressure difference pushing the air through, and I know that if a pipe is constricted and then opened up again, there will be a pressure difference between the two sides. Will the vessel require an hourglass shape? or simply a taper from one end to the other? I assume if the hourglass shape is used then the highest pressure difference would be between the narrowest point and the air outlet (from which the air is pumped) as the constricted diameter would reduce the flow.
The aim of this vessel is for it to hold a capped rubber tube open (as per the classic balloon-lung demonstration where the balloon is connected by a pipe to the outside and the air is sucked out, causing the balloon to inflate) and then, as the valve is opened, the tube constricts onto a metal cylinder which is placed inside the rubber tube. The need for a pressure difference is that I want the rubber tube to deflate at the capped end slightly before the open end as the valve closes, to try and eliminate any air entrapment between the tube and the cylinder. If the open end deflates first, then the air inside the tube will have no means to escape.
It's all still at the "thought experiment" stage right now, so any alternative means to achieve this will also be gratefully received.
