Pressure for ideal gas in terms of stat.
In summary, the conversation discusses the expression for pressure of a perfect gas when the momentum distribution n(p) is given. The conversation goes on to explore the impact of particles colliding with a wall and how it relates to the pressure on the wall. The correct expression for pressure is determined to be P = 1/3 * \int pvn(p)dp.
KFC
488
I am trying to deduce the expression for pressure of perfect gas when the momentum distribution [tex]n(p)[/tex] is given.
Here is how I did. First we assume a box with side length [tex]L_x, L_y, L_z[/tex], when a particle , say moving a long x direction, collide with one side of the wall, the total change of momentum would be
[tex]\Delta p_x = -2m v_x[/tex]
Assume it takes time t for one round-trip (from one wall to the oppsite and come back), hence
[tex]t = \frac{2L_x}{v_x}[/tex]
and 1/t is the rate of colliding.
Now consider the average impact per unit time,
[tex]\overline{f} = \Delta p_x \times (\textnormal{rate of colliding}) = 2mv_x \frac{v_x}{2L_x} = \frac{mv_x^2}{L_x}[/tex]
For N particles, the total average impact per unit time would be
[tex]\overline{F} = \sum_i^Nf_i = \sum_i^N \frac{mv_{ix}^2}{L_x}[/tex]
Hence, the pressure on the side [tex]A=L_yL_z[/tex] woule be
[tex]P = \frac{\overline{F}}{A} = \frac{\overline{F}}{L_yL_z}[/tex]
For continuous case, the average impact becomes
[tex]\overline{F} = \int \frac{pvn(p)}{L_x}dp[/tex]
So, the pressure becomes
[tex]P = \frac{\overline{F}}{A} = \int \frac{pvn(p)}{L_xL_yL_z}dp[/tex]
In unit volume, [tex]L_xL_yL_z=1[/tex], wehave
[tex]P = \frac{\overline{F}}{A} = \int pvn(p)dp[/tex]
I know there is something wrong here. The correct answer should be
[tex]P = \frac{1}{3}\int pvn(p)dp[/tex]
Well, I don't know where my reasoning is going wrong. From [tex]\overline{F} = \sum_i^N \frac{mv_{ix}^2}{L_x}[/tex] to [tex]\overline{F} = \int \frac{pvn(p)}{L_x}dp[/tex], I feel that there is something missing?
Because when you say N particles with the side L_yL_z, you say that all of the particles move in the x direction. Whereas in average only one third of the particles move in the x direction.
So you should divide the average rate of impact by three for all three directions...
I appreciate your effort to deduce the expression for pressure of an ideal gas in terms of the momentum distribution n(p). Your reasoning is mostly correct, but there are a few things that need clarification.
Firstly, your assumption of a box with side lengths L_x, L_y, L_z is a good starting point. However, it is important to note that this is a simplified model and in reality, the particles in a gas are constantly moving in all directions.
Secondly, in your calculation of the average impact per unit time, you have assumed that all particles are moving in the x-direction, which is not the case. This assumption only holds true for a one-dimensional gas. In a three-dimensional gas, the average impact per unit time would be calculated by considering the velocity components in all directions.
Additionally, your calculation of the total average impact per unit time for N particles is incorrect. It should be the sum of the average impacts of all particles, not the sum of the individual average impacts. This means that the correct expression for \overline{F} would be:
\overline{F} = \sum_i^N \frac{m}{L_x}(v_{ix}^2 + v_{iy}^2 + v_{iz}^2)
Furthermore, in your continuous case, the expression for the average impact per unit time should be:
\overline{F} = \int \frac{pv_xn(p_x)}{L_x}dp_x \int \frac{pv_yn(p_y)}{L_y}dp_y \int \frac{pv_zn(p_z)}{L_z}dp_z
where n(p_x), n(p_y), and n(p_z) are the momentum distributions in the x, y, and z directions respectively.
Finally, the correct expression for pressure would be:
P = \frac{1}{3}\int p(v_xn(p_x) + v_yn(p_y) + v_zn(p_z))dp_xdp_ydp_z
This takes into account the contributions from all three velocity components.
In conclusion, your reasoning is on the right track but there are some key assumptions and calculations that need to be revised. I hope this helps in your understanding of the expression for pressure of an ideal gas in terms of the momentum distribution. Keep up the good work!
FAQ: Pressure for ideal gas in terms of stat.
What is the ideal gas law and how is pressure related to it?
The ideal gas law is a formula that describes the relationship between the pressure, volume, temperature, and number of moles of a gas. It is written as PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature. In this equation, pressure is directly proportional to the number of moles and temperature, and inversely proportional to the volume.
How is pressure defined in terms of statistical mechanics?
In statistical mechanics, pressure is defined as the force per unit area exerted by gas molecules on the walls of a container. It is derived from the average force of gas molecules colliding with the walls of the container, and is related to the kinetic energy and speed of the molecules.
What is the relationship between pressure and temperature for an ideal gas?
According to the ideal gas law, pressure and temperature are directly proportional, meaning that as temperature increases, pressure also increases. This is because at higher temperatures, gas molecules have more kinetic energy and therefore collide with the walls of the container more frequently and with greater force, resulting in a higher pressure.
How does the volume of an ideal gas affect its pressure?
According to the ideal gas law, pressure and volume are inversely proportional, meaning that as volume increases, pressure decreases. This is because when the volume of a container increases, there is more space for gas molecules to move around, resulting in fewer collisions with the walls of the container and a lower pressure.
What are the units of pressure in the ideal gas law?
In the ideal gas law, pressure is typically measured in units of atmospheres (atm), millimeters of mercury (mmHg), or pascals (Pa). However, other units such as torr, bar, and kilopascals (kPa) are also commonly used. It is important to use consistent units when solving problems using the ideal gas law.
