B Pressure in fluid (liquid)
  • B
  • Thread starter Thread starter adjurovich
    Pressure
When pressure is applied to the surface of a liquid, such as water in a glass, the pressure increases uniformly throughout the liquid. This uniform increase occurs because pressure is a scalar quantity that acts isotropically in all directions, unlike stress, which can vary. When a spoon presses on the water's surface, it disrupts equilibrium, causing fluid movement and creating viscous stresses that can lead to non-isotropic conditions. However, once the system stabilizes, the overall pressure throughout the glass will have increased. Understanding this dynamic helps clarify the distinction between pressure and stress in fluid mechanics.
adjurovich
Let’s imagine a glass of water. Now, we press on the free surface of water with a spoon (just for example), will the pressure in the entire glass increase equally?
Science news on Phys.org
Yes. Is there some reason that isn’t clear to you?
Thanks for help. I’ve been struggling to understand the term pressure because I would always think of directions… due to this definition: “it acts in all directions”. However, knowing that pressure is a scalar quantity, just like mass, I thought I should give it a different approach. Interestingly, when I did thermodynamics, the term pressure was perfectly intuitive to me (and still is when talking about gases), but with liquids it felt like a whole different story and I got lost. So I choose to apply thermodynamical approach to liquids too and that’s why I asked this question. I feel like I am slowly, but surely, connecting all information and knowledge I’ve gained so far about fluids
Likes Field physics
When someone is thinking about pressure “acting in a direction” what they are actually thinking about is a quantity called the stress.
Stress is a tensor so it maps a vector to a vector. In this case an infinitesimal area is represented by a vector perpendicular to the area, and the stress gives the force on that area. So that is exactly what people mean by pressure acting in a direction.
Pressure is the isotropic part of the stress. So it acts in all directions because if it didn’t then it wouldn’t be pressure, it would be stress. Not all stress is isotropic, not even in a gas or a liquid. But if the stress isn’t isotropic then we don’t call it pressure. So there isn’t anything particularly magical about pressure being isotropic, that is just its definition.
If you person on the free surface with a spoon, the system will no longer be in equilibrium, and the spoon will begin descending into the fluid. The fluid at the surface of the spoon will be moving at the spoon velocity, while the fluid further away will be moving more slowly, and the fluid at the wall of the glass will not be moving. So the fluid will be deforming and, in terms of what Dale has pointed out, there will be viscous stresses developed within the deforming fluid, such that the state of stress is no longer isotropic.
Chestermiller said:
If you [press] on the free surface with a spoon [...]
The mental picture I have is of a spoon pressing down into the water without submerging. Like a tiny boat that is forced a bit into the water.
Naturally, the surface of the fluid in the rest of the glass will rise slightly due to the displaced water. Naturally, this in turn means that pressure throughout the glass increases -- once the ripples die down and a new equilibrium is reached, anyway.
Likes adjurovich and Chestermiller
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
