Pressure, temp, volume change of water vapor, and steam table clarity
In summary, the problem involves determining the pressure of water vapor after a partition is removed and heat is transferred, causing the temperature to reach 40°F. The initial state is described as having two pounds of water vapor at 30 psia filling a 4ft^3 chamber, while the right chamber has twice the volume and is initially evacuated. The attempt at a solution involves using known properties to calculate the initial temperature using steam tables and interpolation. The user also mentions the need to look at superheated vapor tables and asks for help understanding how to read them. The conversation then delves into a discussion about the ideal gas law and the limitations of using it for water vapor. The user also expresses a desire for a better understanding of interpreting the
wmgabe74
Two pounds of water vapor at 30 psia fill the [itex]4ft^3[/itex] left chamber of a partitioned system. The right chamber has twice the volume of the left and is initially evacuated. Determine the pressure of the water after the partition has been removed and enough heat has been transferred so that the temperature of the water is [itex]40^°F.[/itex]
The change in internal energy is heat minus work, [itex]ΔU=Q-W[/itex] where work done by the system is positive.
Steam tables
[itex]water = 0.0397 lb/mol[/itex]
I begin with my known properties of state: for state one (before partition removal), I have the following:
m = 2 lbs water
P = 30 psia
V = 4ft^3
T = ?
U = ?
State two:
m = 2 lbs water
P = ?
V = 12ft^3 (the original space plus eight more cubic feet)
T = 40 °F.
U = ?
I want the initial temperature, so using the steam tables and interpolation, I find 30 psia falling between values as follows: 29.823 psia at 250 °F and 35.422 psia at 260 °F. My calculation results in 250.316 °F, which looks reasonable.
My questions begin...
My understanding of the steam table values is lacking clarity I believe. Here is what I think: When I look at these values of pressure and temperature for Saturated water, I see specific volumes between 13 and 11 cubic feet per molar pound, between 29.8 and 35.4 psia. With the problem giving me 2 lbs. of water, it seems to me I need nearly 26 cubic feet of volume to achieve the stated temperature of 250.316 °F. Pushing the vapor into a smaller area, 4 cubic feet, should require work done on the system, adding to the internal energy. This internal energy should be seen as increased temperature, if the pressure is to be held at the 30 psia stated. I need to look at the superheated vapor tables.
Assuming this is all correct, I don't think I understand how to read the superheated table.
two sections are headed as follows: 20psia(227.96 °F) and 40psia(267.26 °F). The first two columns are Temp (°F) and specific volume V (cubic feet per molar pound).
Do I use these section headings and my 30psia to interpolate my initial temperature?
This would give me an initial temperature of 247.61 °F.
How does the vapor being in 4 cubic feet play into my initial state?
State two pressure should be less, with a larger volume, and the cooling to the final temperature, but I am unclear regarding moving from state one to state two.
40 °F has a specific pressure of 0.122psia in the saturated water table...and a much higher specific volume rating, 2445.1 for saturated vapor, suggesting a higher pressure for the temp to be held constant at the 12 cubic feet of volume allowed.
I can determine my internal energy, U of state one, find the difference between that and the U at state two, but this comes after the above.
I am not looking for a specific answer to the problem here, but help understanding where I am going awry would be appreciated.
Im honestly not sure what youre talking about. When you calculated the initial temperature, what were you using? You have enough information to figure it out, and it appears as though youve don that. If you did, then why are you trying to compress it more?
With the initial temperature known, you know the initial state of your water.
You now only need to solve for the one unknown variable in the second state. Since you seem to be looking at energy, does it matter how i add energy to a system? (Meaning chronologically) if the water moves over to the other chamber, what happens to the energy of the water as a whole? Does it matter if i heat it before or after my "change in pressure energy exchange"?
State 1 is state 1, state 2 is state 2. Does it matter how it got there?
Last edit.
What kind of gas are you treating water as?
Thank you for the reply.
"What kind of gas are you treating water as?"
The closer to liquid a gas gets, the higher the error when using the ideal gas laws. One of the assumptions in using an ideal gas law such as [itex]PV=nRT[/itex] is that there are no molecular interactions (low density). This becomes questionable with water vapor. In short, I cannot use the ideal gas equations of state for this, (also a requirement of my class, but there is a certain sense to this, even without the professor's decree). This is why the steam tables are in play for this question.
It is correct that for the answer to the problem I only need to solve for the final pressure. I am seeking greater understanding however, in looking at the energy. I am aware that when the energy is used is not relevant, this is inherent in the concept of first and second states. With a better understanding in interpreting the steam tables, I can find the internal energy, and subsequently the change in heat.
I am not trying to compress the vapor more, the problem states a static first state of 4 cubic feet for a volume; pressure is force applied divided by an area - if there is no volume at all (free space), there would be no pressure, or perhaps ambient pressure, if we are talking open space. This indicates there is a pressure associated with volume;
This leads me to consider that the specific volumes in the steam tables only work for the pressures and temperatures they are associated with. If my given volume of water vapor is different, I think either my temperature or my pressure must change. Is this not correct? From that if my pressure is stated in the problem, I must change the temperature.
My question is, if this is incorrect, why? or where is my reasoning inaccurate?
Sorry to leave you hanging for so long. But, in short, yes, that works logically. I'm not sure what you were saying about energy however,
You have an initial state, of which you know certain conditions. I'm not familiar with these steam table things that you're talking about (is this engineering?), but regardless, ideal gas law is a good first order approximation. You can't use IGL, which is fine, but if you look at the relationship between Pressure Volume and Temperature you can see that you have the right idea, and you can see how they (approximately) vary with respect to each other.
So does that answer your question, then? If not please rephrase it so I or someone else here can help you better.
The end result of this problem is that I was way overthinking the problem. In the steam tables, the pressure for saturated liquid water at the final temperature of 40 degrees F was given, and that was it.
Thanks for your looking at it, BiG
Anytime. Glad you got it figured out.
Related to Pressure, temp, volume change of water vapor, and steam table clarity
1. What is the relationship between pressure and volume change of water vapor?
The relationship between pressure and volume change of water vapor is known as Boyle's Law. This law states that at a constant temperature, the volume of a gas (in this case, water vapor) is inversely proportional to its pressure. This means that as pressure increases, the volume of water vapor decreases, and vice versa.
2. How does temperature affect the volume of water vapor?
According to Charles' Law, the volume of a gas (such as water vapor) is directly proportional to its temperature, as long as pressure remains constant. This means that as temperature increases, the volume of water vapor also increases, and vice versa.
3. What is the difference between water vapor and steam?
Water vapor is the gaseous form of water, while steam is the vapor that forms when water is heated to its boiling point and changes from a liquid to a gas. Water vapor is typically invisible, while steam is visible due to the presence of tiny water droplets.
4. What is a steam table and how is it used?
A steam table is a tool used to determine the properties of water and steam at various temperatures and pressures. It includes information such as specific volume, enthalpy, entropy, and internal energy. Steam tables are commonly used in thermodynamics and engineering to calculate the properties of steam in different processes.
5. How can I read a steam table and interpret the data?
To read a steam table, you will need to know the temperature and pressure at a specific point. Then, you can locate those values on the table and use the corresponding data to calculate other properties, such as specific volume or enthalpy. It is important to pay attention to the units of measurement used in the steam table and make conversions as necessary.
