Preventing Hysteresis in homemade Force Sensing Resistors
In summary: You could probably shrink it to about the size of a postage stamp though. With regards to the non-flat surface, I think it would have a small effect but it would be hard to quantify.
JohnnySmithy
Hello, I am new to the forums and physics in general. I hope I am not posting in the wrong place. My understanding of physics in general is rudimentary at best, so please let me know if any of my statements are incorrect.
I understand this is an extremely long post, so feel free to jump to "The Problem" below if you are already familiar with what I'm talking about.
Background:
My friends and I have started a new hobby project of trying to create a wearable Force Sensing Resistor (FSR) to take rough readings of forces around the ranges of 1-100 pounds. The wish is that we would be able to create a very dumb-downed version of this device. We thought it would be very cool to be able to pick something up and have the device let us know how much weight we are carrying.
We decided to focus on several materials whose resistance changes inversely when a force is applied on it. We were hoping to map out the resistance output of the material by applying known weights on it. Essentially, we were hoping to regress the predetermined weights (the Y-variable) on the resistance output (the X-variable), so that when an unknown object on the sensor produces a resistance output (X), we can predict the weight of it (Y).
The Materials and Set Up
We decided to focus on "smart" materials, such as velostat and quantum tunneling composite (aka QTC). We didn't focus on the traditional conductive ink printed FSRs because the ones available online seemed a bit bulky/rigid for our applications, though we should definitely explore it.
  1. Velostat
    Velostat is a type of conductive material that can be commonly found in packaging materials for electronics to prevent static​
    With velostat, we were hoping to recreate this device on page 2: WARNING .PDF FILE
  2. Quantum Tunneling Composite (QTC)
    QTC is a strange type of material that is an inductor at rest and a conductor when stressed​
    With QTC, we were hoping to recreate something similar to the device on page 2, application 3: https://www.mindsetsonline.co.uk/images/QTC.pdf​
Our setup was pretty basic: the sensor was attached to the multi-meter with the meter set to measure resistance. We laid something flat on top of the sensor so that any weight on top of the sensor would be distributed evenly. We then applied the weight and measured the resistance.
The Problem
To cut to the chase, the resistance output measured by the multi-meter was never stable for any of the materials. We couldn't establish a relationship between weight/force and resistance output since the resistance would be decaying at a (seemingly) unpredictable rate. We surmise that the material is adapting to the weight and forming around it, lowering the resistance.
How can we solve this "hysteresis"? Is there any way to work around it? Any advice on any aspect of our project would be appreciated.
Also, we've been trying to get our hands on a type of material called Eeoynx, which seemingly produces consistent readings, as show in this Youtube video. The only problem is that this material is incredibly expensive and hard to get. Does anyone have any experience with this type of material?
Anyway, I hope my post didn't go too long. I appreciate any help or advice. Thank you.
You could try using a strain gauge. I think most force sensors suffer from drift effects so often you just measure changes of force.
How big are most strain gauges? Can I realistically "shrink" it so that I can use multiple strain gauges to cover areas of the hand?
Also, do I need to apply it to a completely flat surface? How much of an effect does the non-flat surface of the hand have on the gauge?
Thank you.
Well I guess with a glove it wouldn't work too well. The nice thing about the strain gauge is, that is measures geometry and thus the underlying material defines the proportionality constants, but I don't think it would produce a lot of useful signal if you bend it in you hand by gripping something.
Hello and welcome to the forums! Your understanding of physics is quite impressive for someone new to the field. I would like to offer some insights and suggestions for your project on preventing hysteresis in homemade force sensing resistors.
Firstly, it is important to understand the concept of hysteresis in relation to force sensing resistors. Hysteresis is the phenomenon where the output of a material does not directly correspond to the input force. In other words, the resistance of a material may not return to its original value after being subjected to a certain force. This can be caused by factors such as material properties, temperature changes, and the duration of the applied force.
Based on your description, it seems that you have already identified the issue of hysteresis in your homemade force sensing resistors. The materials you have chosen, velostat and QTC, are known to have high hysteresis. These materials are also highly sensitive to changes in temperature and humidity, which can also affect their resistance output.
To prevent hysteresis, here are some suggestions:
1. Use a more stable material: As you have mentioned, Eeoynx seems to produce consistent readings. This is because it is a more stable material compared to velostat and QTC. However, as you have also noted, it can be expensive and difficult to obtain. You may want to consider other materials such as piezoresistive materials, which have a lower hysteresis and are also less sensitive to temperature and humidity changes.
2. Improve the setup: The setup of your force sensing resistor may also contribute to hysteresis. As you have mentioned, the weight on the sensor may cause the material to form around it, leading to a decrease in resistance. To prevent this, you can try using a more rigid surface to distribute the weight evenly. You can also consider using a smaller contact area to reduce the effect of the weight on the material.
3. Experiment with different force ranges: Hysteresis is more prominent in lower force ranges, as the materials are more sensitive to smaller changes. You may want to consider experimenting with higher force ranges, where the hysteresis effect may be less significant.
4. Account for temperature and humidity changes: As mentioned earlier, temperature and humidity can affect the resistance output of the materials. To prevent this, you can try to keep the temperature and humidity constant during your experiments. Alternatively,
Related to Preventing Hysteresis in homemade Force Sensing Resistors
Frequently Asked Questions About Preventing Hysteresis in Homemade Force Sensing Resistors
1. What is hysteresis and why is it important to prevent it in homemade force sensing resistors?
Hysteresis is the phenomenon where the output of a sensor does not return to its original value after the input signal has been removed. In homemade force sensing resistors, hysteresis can cause inaccurate measurements and affect the overall performance of the sensor. Therefore, it is important to prevent hysteresis to ensure accurate and reliable readings.
2. What factors can contribute to hysteresis in homemade force sensing resistors?
There are several factors that can contribute to hysteresis in homemade force sensing resistors, including the quality and type of materials used, the construction of the sensor, and the calibration process. Inadequate or inconsistent pressure application, temperature changes, and material fatigue can also contribute to hysteresis.
3. How can hysteresis be prevented in homemade force sensing resistors?
To prevent hysteresis in homemade force sensing resistors, it is important to use high-quality and consistent materials, carefully construct the sensor with proper layering and adhesive techniques, and calibrate the sensor properly. The sensor should also be kept at a consistent temperature and not be subjected to excessive pressure or strain.
4. Can hysteresis be completely eliminated in homemade force sensing resistors?
While it is difficult to completely eliminate hysteresis in homemade force sensing resistors, it can be minimized through careful construction and calibration techniques. The goal is to reduce hysteresis to a negligible amount so that it does not significantly affect the accuracy of the sensor.
5. Are there any additional tips for preventing hysteresis in homemade force sensing resistors?
In addition to using high-quality materials and proper construction and calibration techniques, it is also important to regularly test and calibrate the sensor to ensure accurate and consistent readings. It is also recommended to follow any specific guidelines or recommendations provided by the manufacturer of the materials used in the sensor construction.
  • Electromagnetism
  • Astronomy and Astrophysics
  • DIY Projects
  • Electrical Engineering
  • STEM Educators and Teaching
  • Aerospace Engineering
  • Other Physics Topics
