Chemical/Paint Primer applied on waterproof putty became flaky and peeled off
  • Thread starter Thread starter Wrichik Basu
    Diy
Flakiness on a wall behind an air conditioner was caused by dampness and poor initial plastering, leading to the application of waterproof putty and primer. After applying the primer without dilution, the wall began to peel, possibly due to high moisture content in the putty or improper curing. The discussion highlights that moisture could push the paint off, and suggests using moisture-permeable paint as a remedy. Concerns about the primer scraping off the putty have led to a decision to delay further application. The situation remains unresolved, with some primer still intact on parts of the wall.
Wrichik Basu
Insights Author
A section of the wall in our house developed flakiness due to dampness, prompting us to undertake repairs. Specifically, the affected area was located behind an air conditioner. It appeared that poor initial plastering, combined with water leakage from the old AC indoor unit, caused the concrete to become flaky. Consequently, the old plaster was removed, exposing the brickwork, and a new layer of plaster was applied by a professional mason. Once this was completed, I proceeded to apply a layer of waterproof putty, specifically, this product.
After allowing the putty to dry, I noticed certain areas that appeared thin, so I decided to apply an additional layer without sanding the surface. My intention was to maintain the layer's thickness. Although the resulting surface was not perfectly smooth, it wasn't of great concern since it was a wall hidden behind an air conditioner. The main objective was to protect it from dampness for as long as possible.
Once the second layer of putty dried, I proceeded to apply a waterproof primer. I used this particular primer, which, according to the technical data sheet, could be thinned with water. However, it did not explicitly state whether dilution was necessary. To clarify, I consulted with the shop owner from whom I purchased the primer, and he confirmed that thinning the primer was not strictly required.
Consequently, I applied the primer as is, without diluting it. As it began to dry, the wall started to exhibit flakiness:
Before long, the entire wall peeled off. I believe the primer removed a layer of putty as well. All labour lost.
In order to rectify the situation, I will need to apply another layer of primer. However, before proceeding, I need to understand why the primer peeled off. Do you have any insights into the possible reasons behind this issue? I believe I have to thin the primer, right?
Just guessing here. According to the paint data sheet, the substrate must:
1) Have less than 12% moisture
and
2) pH between 7 and 11
The data sheet also mentions water resistance. One possibility is that the putty still has high moisture content, and possibly high or low pH. It is also possible that moisture is coming through from behind the putty. If so, the moisture in the putty can push the paint off. I have seen a mural painted on a brick building peel off exactly like in your photos. That building was part of a paper mill, and had high moisture inside.
Joseph Lstiburek has done a lot of research into moisture flow in walls. His web site has a lot of good information in the subject. This link is to just one article on that web site: https://buildingscience.com/documents/building-science-insights/bsi-135-throttling-flow.
A remedy would be to remove all of the primer, and repaint with a moisture permeable paint. Most water base latex paints are moisture permeable. Put on just enough paint to get coverage because too much paint makes it less permeable, and more likely to flake off.
Likes Lnewqban and BillTre
@jrmichler Thank you for the reply. It is possible that the upper layer of putty had not dried and cured fully, which is why when the primer dried and shrunk, the top layer came off.
I doubt that moisture can come from behind the putty in this wall. There are no water pipes; it's nearly 40°C for the past few days, with humidity quite low as well. The external wall is painted properly. No rain in the past few weeks either.
For the while, I have not applied another coat of primer, primarily out of fear that it may scrape off the lower layer of putty. Some portions of the wall still have the primer; some don't. We will leave it like that for the moment. We will not be painting the surface because of budget reasons.
Hey folks! So I’m kinda losing my mind over my hedgie’s setup lately. No matter what I do, the enclosure keeps getting super humid and it’s starting to smell funky. I clean it, switch bedding, crack the window, the whole nine yards… but it still ends up damp and I’m worried it’s gonna mess with my little dude’s health. I’m starting to feel like I’m doing something wrong even though I’m trying so hard. Has anyone dealt with this before? Any tips, hacks, gear recs… literally anything would...
  • · Replies 19 ·
  • · Replies 78 ·
13K
  • · Replies 65 ·
11K
