Principal ideal in a ring without identity
In summary, we are given a commutative ring without identity and an element a in that ring. We need to prove that A, defined as the set of all elements in the form of ra + na, where r is in the given ring and n is in the set of integers, is an ideal containing a. Additionally, we need to show that any ideal containing a must also contain A. To prove this, we need to show that A is a subgroup of the ring under addition and that it absorbs multiplication from both sides. We can also use the fact that $0_R \cdot a = 0_R$ and interpret $na$ as "a added n times" to simplify our calculations.
Math Amateur
MHB
3,998
48
(Hungerford exercise 31, page 143)
Let R be a commutative ring without identity and let [TEX] a \in R [/TEX]
Show that [TEX] A = \{ ra + na \ | \ r \in R, n \in \mathbb{Z} \} [/TEX] is an ideal containing a and that every ideal containing a also contains A. (A is called the prinicipal ideal generated by a)
Hi Peter! :)
It would be helpful if you showed something about how far you got and/or what is puzzling you.
Anyway, you need to prove:
  1. $(A,+)$ is a subgroup of $(R,+)$
  2. $A$ absorbs multiplication from both sides
  3. $a \in A$
  4. If $I$ is an ideal with $a \in I$, then $A \subseteq I$
To prove a subgroup, it suffices that A is non-empty and that for any 2 elements x and y in A holds: $x-y \in A$.
A is non-empty, since $(0a+0a) \in A$.
When we pick arbitrary $x=r_1 a + n_1 a$ and $y=r_2 a + n_2 a$, it follows that $x-y=(r_1 - r_2)a + (n_1-n_2)a \in A$.
Therefore $(A,+)$ is a subgroup of $(R,+)$.
How far can you get with 2?
Thanks for the help so far - I just lacked the confidence to start this problem - my issue was the nature of na where \(\displaystyle n \in \mathbb{Z} \) and not in R
But thinking about it na probably equals a + a + a ... (n times in all) which is in R since R includes an additive group in its structure.
But perhaps you can clarify your use of \(\displaystyle 0_R a + 0_{ \mathbb{Z} } a\)
I am uneasy about this ... is \(\displaystyle 0_R \) the same as \(\displaystyle 0_{ \mathbb{Z} } \) and does it matter? But how do we proceed with a sum with different elements in it - perhaps it does not matter since the sum is clearly in a set that contains ra + na and we do not have to add them?
Can you clarify?
Peter
Can you clarify?
Peter
Good! ;)
You have it totally right.
The symbol $0_{ \mathbb{Z} }$ and any number in $\mathbb{Z}$ has to be carefully distinguished from elements in R, since it is not given that they are elements of R.
The expression $na$ is merely a shorthand for repeatedly adding $a$ as you already surmised.
Keeping that in mind, and expanding it when in doubt, you can address the problem.
So when I wrote $0 a + 0a$, I meant $0_R \cdot a$ with $a$ added zero times.
The result is $0_R$ (did you know that $0_R \cdot a = 0_R$?), which is therefore an element of $A$.
Thanks again for your help
Yes, I was aware that \(\displaystyle 0_R \cdot a = 0_R \) but was worried about \(\displaystyle 0_{ \mathbb{Z} } \cdot a\) which I took to result in \(\displaystyle 0_{ \mathbb{Z} } \) leaving us the sum \(\displaystyle 0_R +0_{ \mathbb{Z} } \) and I did not really know how one should interpret this.
It seems that you have (qualitatively) interpeted \(\displaystyle 0_{ \mathbb{Z} } \cdot a\) as "a added zero times" and hence dropped the term. I lacked your confidence to make what I take to be a qualitative interpretation.
What do you think about my concerns?
Peter
Peter
Consider how A is constructed.
We start with a.
The ring contains both multiplication and addition as operations.
So to construct an ideal, we need to multiply each element (starting with only a) by any number r, generating a set of new elements for A.
Then we add any element that is already in A (starting with a) to the known elements, which are $r\cdot a$ by now.
This generates $r\cdot a +a$ as the first new element, but then we can add $a$ again, generating $r \cdot a + a + a$.
Now we need to start to think how to write this down in a comprehensible way.
So let's introduce $r\cdot a + na$ to denote this.
And then...
Oh wait! Now I've almost answered the 4th part, proving that any ideal that contains a must also contain A. :eek:
Thanks ... That post made things very clear!
Most helpful indeed
Peter
FAQ: Principal ideal in a ring without identity
What is a principal ideal in a ring without identity?
A principal ideal in a ring without identity is a subset of the ring that is generated by a single element. This means that all elements in the ideal can be obtained by multiplying the generator by any element in the ring.
How is a principal ideal different from other types of ideals?
A principal ideal is different from other types of ideals because it is generated by a single element, whereas other ideals may be generated by multiple elements. Additionally, principal ideals are only defined in rings without an identity element.
What is the significance of a principal ideal in a ring without identity?
Principal ideals in rings without identity play an important role in understanding the structure of the ring. They can be used to define quotient rings and to prove theorems about the properties of the ring.
How are principal ideals related to principal ideal domains?
A principal ideal domain is a type of commutative ring where every ideal is a principal ideal. This means that every ideal in the ring can be generated by a single element. Therefore, in a principal ideal domain, all ideals are principal ideals, including those in rings without identity.
Can a principal ideal in a ring without identity be a maximal ideal?
Yes, a principal ideal in a ring without identity can be a maximal ideal. A maximal ideal is an ideal that is not contained in any other proper ideal of the ring. In a ring without identity, a principal ideal can be maximal if it is generated by an irreducible element, meaning it cannot be factored into smaller non-unit elements.
