Principal Ideals - Need for a ring with identity or a unity
In summary, on page 273 of Dummit and Foote, the last sentence reads: "The notion of the greatest common divisor of two elements (if it exists) can be made precise in general rings." (my emphasis)On page 274, the first sentence reads: "Definition. Let R be a commutative ring and let a,b \in R with b \ne 0 ... ... "
Math Amateur
MHB
3,998
48
On page 273 of Dummit and Foote the last sentence reads: (see attachment - page 273)
Then, the first sentence on page 274 reads as follows: (see attachment - page 274)
"Definition. Let R be a commutative ring and let [TEX] a,b \in R [/TEX] with [TEX] b \ne 0 [/TEX]
In this definition D&F go on to define multiple, divisor and greatest common divisor in a commutative ring.
D&F then write the following:
"Note that b|a in a ring if and only if [TEX] a \in (b) [/TEX] if and only if [TEX] (a) \subseteq (b) [/TEX]."
My problem is this - I think D&F should have defined R as a commutative ring with identity since proving that [TEX] (a) \subseteq (b) \longrightarrow a \in (b) [/TEX] requires the ring to have an (multiplicative) identity or unity.
Can someone please confirm or clarify this for me?
Peter
Can you give the proof?
Hello Siron,
Of what do you demand a proof?
I imagined the proof went as follows:
\(\displaystyle (a) \subseteq (b) \longrightarrow ra \in (b) \) for all \(\displaystyle r \in R \)
\(\displaystyle \longrightarrow \) in particular that choosing r = 1 that \(\displaystyle 1.a \in (b) \) i.e. \(\displaystyle a \in (b) \)
I did look for another proof that did not involve assuming \(\displaystyle 1 \in R \) but could not find one.
Peter
Peter
Interesting! :)
It depends on how an ideal generated by a set is defined exactly.
Does $(a)$ contain $a$ or not?
From wiki:
Let R be a (possibly not unital) ring. Any intersection of any nonempty family of left ideals of R is again a left ideal of R. If X is any subset of R, then the intersection of all left ideals of R containing X is a left ideal I of R containing X, and is clearly the smallest left ideal to do so. This ideal I is said to be the left ideal generated by X. Similar definitions can be created by using right ideals or two-sided ideals in place of left ideals.​
I draw the implication that the generated ideal (a) does contain a, even if there is no element r in the ring such that ra=a.
Since $a \in (a)$ and $(a) \subseteq (b)$, it follows from the definition of a subset that $a \in (b)$.
Seems that the question still remains - does \(\displaystyle a \in (a) \)?
Are there any other clarifying thoughts?
I must say I am inclined to the idea that on page 274 D&F should have specified the ring R as a commutative ring with identity \(\displaystyle 1 \ne 0 \)
Peter
Hello ILikeSerena,
Let $R$ be a commutative ring and $a\in R$.
Then $(a)=\{ra:r\in R\}$.
Take $R=2\mathbb Z$. Then the ideal $(2)$ of $R$ doesn't have $2$ in it.
So I don't think that in general $a\in (a)$.
Peter
The wiki section seems to state clearly that an ideal generated from a set X, is the smallest ideal that contains X.
Let's consider the commutative ring $2\mathbb Z = \{0, \pm 2, \pm 4, ...\}$.
When we look at the generated ideal (2), do we mean the multiples of 2, or the multiples of 4?Googling a bit I found here:
Definition
Let (R,+,∘) be a ring.
Let S⊆R.
The ideal generated by S is the smallest ideal of R containing S.​
http://www.math.hmc.edu/~davis/171hw/171lec112.pdf:
Defi nition: The ideal generated by a, denoted (a), is defi ned to be the smallest ideal containing
the element a.​
I do not have Dummit and Foote.
Can you quote how they define an ideal generated by a set please?
- - - Updated - - -
Currently I believe this is only true for commutative rings with unity and not in general for rings.
In particular what you mention is for a left ideal, while I believe $(a)$ is intended for 2-sided ideals.
Just tried to upload 2 pages from D&F on ideal generated by a set but had a problem - as follows:I have two uploads that I have used previously but I cannot delete them. When I try to make a new upload I cannot because the previous old and used files nearly make up my limit - but I cannot delete them - this is a real problem. How can I delete them.
(Thus I have a real problem with the way the MHB deals with uploads. )
Will try to find a way around this problem
Peter
I like Serena said:
- - - Updated - - -
I used a commutative ring. For a commutative ring I think the left ideals, right ideals and two-sided ideals are the same things. Isn't it?
Keeping this in mind don't we have good reason to believe that $a\in (a)$ doesn't hold in general, where $(a)$ is the 2-sided ideal generated by $a$.
Yes.
Not as I see it.
As far as I know, ideals have been invented to generalize properties of numbers.
So we can generalize saying 2 divides 4, by saying (2) divides (4), which actually means that (4) is a subset of (2).
This only makes sense if (2) is really the set of multiples of 2 in $2\mathbb Z$ and (4) the multiples of 4.
More to the point, in the wiki section your definition is given as well, but it is preceded by "If R has unity, then ...".
Some more information for everyone!
Previously I was working on a problem from Hungerford that I believe indicates strongly that \(\displaystyle a \notin (a)\).
The problem is from Hungerford - Abstract Algebra: An Introduction - Section 6.1 Ideals and Congruences, Exercise 31 on page 143:
The exercise reads as follows:
"Let R be a commutative ring without identity and let \(\displaystyle a \in R \).
Show that \(\displaystyle A = \{ ra + na \ | \ r \in R, n \in \mathbb{Z} \} \) is an ideal containing a and that every ideal containing a also contains A. A is called the principal ideal generated by a."
I know this does not go as far as to assert that \(\displaystyle I = \{ ra \ | \ r \in R \} \) does not contain a, but given the special construction involved in A above, it seems this is likely to be the case. The statement of the exercise seems to indicate that when R does not have an identity we have to add in the elements a, a + a, a + a + a, etc to ensure that A is an ideal containing a. (would it even be an ideal without this? Maybe it would?)
Mind you I would really like to see a proof that \(\displaystyle a \notin I\) when R is a commutative ring without identity.
Peter
Mind you I would really like to see a proof that \(\displaystyle a \notin I\) when R is a commutaitve ring without identity.
Peter
It's the other way around.
We have $a \in A$ and furthermore "A is called the principal ideal generated by a", so the principal ideal does contain a.
This confirms that $a \in (a)$.
Also note that A is defined slightly different from $\{ ra \ | \ r \in R \}$ to allow for $a$ being in there, even though R has no unity.
Hi ILikeSerena,
\(\displaystyle a \in A \), certainly, but then A is especially constructed to contain a.
I think that the issue is that \(\displaystyle a \notin I \) (I is just the standard definition of a left ideal - which is same as right and two sided ideals since R is commutative.
What do you think?
Peter
Hi ILikeSerena,
It is very likely we are both actaully saying the same thing - that is when R has no identity the definition of a principal ideal has to be adjusted in the way Hungerford indicates.
Thanks so much for your help in this matter!
Peter
FAQ: Principal Ideals - Need for a ring with identity or a unity
What is a principal ideal?
A principal ideal is an ideal in a ring that is generated by a single element. In other words, it is the set of all elements that can be obtained by multiplying a single element in the ring by any other element in the ring.
Why is a ring with identity necessary for principal ideals?
A ring with identity, also known as a ring with unity, is necessary for principal ideals because it ensures that there is a multiplicative identity element that can be used to generate the ideal. Without a multiplicative identity element, it would not be possible to generate a principal ideal from a single element.
How are principal ideals related to prime ideals?
Principal ideals are a special case of prime ideals. A prime ideal is an ideal in a ring in which the product of any two elements in the ideal is still in the ideal. Principal ideals are prime ideals that are generated by a single element.
Can a principal ideal be generated by more than one element?
No, a principal ideal can only be generated by a single element. If a principal ideal could be generated by more than one element, then it would not truly be a principal ideal.
Are all ideals in a ring principal ideals?
No, not all ideals in a ring are principal ideals. There are also non-principal ideals, which are generated by more than one element. However, every principal ideal is a subset of a non-principal ideal.
