- #106
Dale
Mentor
- 35,855
- 14,311
This is certainly not "our topic" it is only "your topic". You are the only person who is discussing zero gravitational field with your definition meaning absolutely no matter or energy anywhere in the universe. Everyone else was talking about the usual meaning of being far from any significant gravitational sources. I even specified "no significant gravitational sources" rather than zero gravity and yuiop used the clarifying phrase "zero gravitational field far from any significant gravitational sources" to make it clear what he meant.Mueiz said:Because you use it to describe the properties of zero-gravitational field which is our topic and not the properties of the gravitational field of accelerometer which will affect the region in which we want to study the conduct of a particle
But again, your objection doesn't make any sense even within the framework you have stated here. First, you claim that the accelerometers won't work because they are in zero gravity. But if there is an accelerometer then by your definition there is a gravitational field. And so the accelerometers function exactly as I specified. So your whole objection saying that they wouldn't work that way is irrational and self-contradictory. You should have responded to my example by pointing out the gravitational field of the accelerometers. Given your definition that is the only correct response.Mueiz said:At that stage of discussion I would not talk about the problem of the gravitational field of the accelerometer because i was dealing with another incorrect assumption which is that objects can accelerate relative to each other in the absence of gravitational
Also, your statement that a rocket engine in zero gravity would not burn is similarly nonsensical and self-contradictory. You claim that the rocket fuel won't burn because of the zero gravity and you also claim that there will be gravity because of the rocket. You should have responded to that by pointing out the gravitational field caused by the rocket, as it is your response is evasive and self-contradictory.
You have been very dishonest in this discussion. First, you take a non-standard position on the definition of an important term in the discussion. Then, when someone says something that clearly shows that they are using the standard definition you make an objection that on one hand is based on your non-standard definition and on the other hand is contradicted by that same definition. Then instead of clarifying your non-standard definition you spend several pages making similar self-contradictory statements.
