Principles of conservation of energey
  • Thread starter Thread starter djstar
    Conservation
The discussion focuses on a physics problem involving a collision between two trains, where the principles of conservation of momentum are applied to determine their velocity after impact. The user successfully calculated the post-collision velocity to be 37.5 m/s using the momentum equation. For the loss of kinetic energy, the user initially struggled but later calculated the kinetic energy before the collision as 90 MJ and after as 56.25 MJ, resulting in a loss of 33.75 MJ. The conversation highlights the distinction between conservation of momentum and energy in inelastic collisions. The user received guidance on the correct formulas and calculations needed for the problem.
djstar
A train of mass 50 onnes traveling at 6o m/s collides head on into a stationary train which has a mass of 30 tonnes. If the two vehicles lock together after impact, calculate using the principles of conservation of momentum, what will be
a) their velocity after impact?
b) the loss of kenitec energy
i have had a attempt at A but i do no no where to start with B or what formula to use. this is my attempt at A)
M1V1+M2V2=MfVf
M1= 50000kg
M2= 30000kg
V1 = 60m/s
V2 = 0 m/s
MfVf = (50000*60)+(30000*0) = 3000000
3000000/ (50000+30000) = 37.5m/s
Could some one please help with Part b and help me with what formula to use
Although you titled this "conservation of energy" I assume you realize that there is NO conservation of energy here. There is, however, conservation of momentum and that is what you used, correctly, to find the speed after the collision.
The kinetic energy before the collision is (1/2)mv^2= (1/2)(50)(60)^2. The kinetic energy after the collision is (1/2)(50+ 30)(37.5)^2= (1/2)(80)(37.5)^2. Subtract the energy after the collision from the kinetic energy after the collision to find the loss of kinetic energy.
hi hallsofivy thank you for the very prompt reply.
sorry about the title, that was a typo.
ive manged to work out before the collision as 90 MJ and after as 56.2 5MJ so the answer is 33.75 MJ?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
