MHB Probabilities of certain events in a lucky wheel game
The discussion centers on a wheel of fortune game with ten equal sectors, where candidates K1 and K2 spin the wheel to determine a winner based on the numbers spun. To ensure at least one draw with a probability of at least 0.95, a minimum of seven candidate pairs must participate. The probability of a draw in a single match is calculated as 0.38, leading to the conclusion that at least seven matches are needed to achieve the desired probability. Additionally, the probability that at most 143 out of 376 matches end in a draw raises questions about the application of the binomial theorem. The conversation highlights the mathematical approach to determining probabilities in this game scenario.
emmi2104
Given information:
A wheel of fortune with ten equal sectors is used for a candidate game. Five of these sectors are labelled only with the number 1, three only with the number 2 and two only with the number 3.
The game for a pair of candidates is as follows: The two candidates �K1 and K2, independently of each other, each spin the wheel of fortune once. The winner is the candidate who has "spun" the higher number. If the numbers are the same, the game ends in a draw.
  • f) The game described above is played with 𝑛 pairs of candidates. What is the minimum number of candidate pairs with which the game must be played so that with a probability of at least 0.95 at least one game ends in a draw?
and
  • h) With what probability 𝑝 do at most 143 of the 376 matches end in a draw?
Mathematics news on Phys.org
I see this is an old unanswered question. Perhaps it was a homework problem at one time. I would start by finding out the probability of (not a tie) in a single match.
That would be 1 - (0.5^2+0.3^2+0.2^2) = 0.62
Now what's the minimum value of n s.t. 0.62^n <= 0.05? Trial and error (or taking the log of .05 base 0.62 and rounding up) says 7
Does h require the binomial theorem?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
