Probability: Average Size of Group A when Choosing Item from 1 to n
  • Thread starter Thread starter Gekko
    Probability
Gekko
We choose two groups where group A can be of size X where X ranges from 1 to n-1. Group B is the remaining (n-X).
All values of X are equally likely and all group sizes are equally likely
If we choose one item from 1 to n where all choices are equally likely, what is the average size of the group containing the item?
Originally I tried the following:
Average size of group A is simply n/2 as it is uniformly distributed and therefore, since the item can be in either group, the size must also be n/2
However, given that the item is more likely to be in the larger of the two groups, we must skew the average to greater than n/2 and indeed, when I run an Excel simulation, that proves correct. Any thoughts on this?
The solution can be obtained form considering the first 1 to n-1 samples which must all be equally likely to be chosen
This yields
1/n(n-1) * [sum from 1 to (n-1) (x^2 + (n-x)^2)]
and has been verified. Can be simplified further. There must be another way to do this though? A more elegant method perhaps?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
