Probability distributions using 4 dice
The discussion focuses on calculating the probability distribution for the largest number shown on four dice, denoted as X. The cumulative distribution function is given by P(X ≤ x) = (x/6)^4 for x values from 1 to 6. To find P(X = x), one must compute (x/6)^4 and then subtract the cumulative probabilities of all lower x values. Participants encourage attempting calculations for specific values, such as x=2, to understand the process better. This approach helps clarify how the probabilities for each outcome are derived.
i_love_science
Moved from a technical forum,
Let X denote the largest number shown on the four dice. P(X ≤ x) = (x/6)4 , for x = 1,2,3,4,5,6.
Complete the following table:
x123456
P(X=x)1/129615/129665/1296175/1296369/1296671/1296
The values in red are the answers, I don't understand how the answers were found. Thanks.
Do you know that ##P(X \leq x) = P(X = 0) + \dots + P(X=x)##? To find ##P(X=x)## you work out ##(x/6)^4## and then subtract all of the previous probabilities to the left.
Likes i_love_science
@i_love_science, you will have to make an attempt at a solution if you want more help.
Try to figure out the answer for x=2. If you can figure it out, it will show you a path to do the higher numbers.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
