MHB Probability of Having a Disease
  • Thread starter Thread starter LostMinosHeins
    Disease Probability
The CDC reports that 1 in 102 males from a specific demographic have HIV, translating to a 0.98% chance of infection. A swab HIV test has a 91.7% accuracy rate, meaning that 12 out of 13 HIV-positive individuals will test positive. However, if someone tests negative, the probability of them actually having HIV is not straightforward, as it involves understanding the test's false negative rate and the base rate of HIV in the population. Calculating the likelihood of having HIV after a negative test requires careful statistical analysis, considering whether the events are independent or dependent. This discussion highlights the complexity of interpreting HIV test results in relation to demographic statistics.
LostMinosHeins
According to the CDC 1 out of 102 persons who are males of a particular demographic have HIV. That mean's there is 1/102 = .98 * 100 = 1% chance of having HIV. There is a swab HIV test available that is 91.7% accurate at being able to identify HIV positive people. This means that 12 out of 13 people who are HIV positive will test positive on the test.
So say a person takes this HIV test and they fit into the demographic of the CDC statistic. If 1/13 people who are HIV positive tests negative on the test, it seems there is an 8.3% possibility that any person taking the test in general period is HIV positive, is that correct? On its face it doesn't seem to make much sense because it doesn't even put you below the 1% chance you have HIV if your a male in the USA according to the CDC. So that does that really mean that being a male in the USA according to the CDC makes you less likely to have HIV than being a person who tests negative on the swab test? It might be comparing apples and oranges because the 1/13 number assumes every one of the 13 has HIV but it would still be useful to compare them.
But using the 1% statistic and assuming the person is a randomly selected individual of that demographic it seems (logically) like the possibility would be reduced from 1% if someone of that category tested negative on the test. It seems like a compound statistical problem, is there a way of calculating how far below 1% a person who has tested negative on the swab test now has of having HIV using these two statistics? One statistic it looks like assumes every person being tested is HIV positive and the other one is a random sample of all males in the US of a particular demographic but it would be informative to use them to be able to derive this i just don't know if they can be because i was told if you use the rule of multiplying statistics they have to be of the same group and add up to 100. I think it depends whether the probabilities represent independent or dependent events. Which category do these two events fall into two? And how can they be manipulated to calculate how likely it is that the person has HIV if they fall into both categories?
Mathematics news on Phys.org
.98 *100 is 98, not 1% but what you mean is 1/102= 0.0098 which 0.98% which is approximately 1%
I'm not sure what this is supposed to mean.
Suppose we have 10000 people. 10000/102= 98 people who have the disease. That is 98/10000= 0.98% just as you said above. You haven't yet said anything about testing positive or negative on this test. Saying that the test is "91.7% accurate" means that 91.7% of people who have HIV will test positive and 91.7% of people who do not have it will test negative. (It is more common to have different percentages for these two cases but this may be a simplification.) Of the 98 people who have the disease, 91.7% of them, 98(0.917)= 90 will test positive and or the remaining 10000- 98= [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]99902,, 100- 91.7= 8.3%, .083(99902)= 8292, will also test positive. So a total of 90+ 8292= 8382 people tested positive of whom 90 actually have the disease. If a person tests positive on the test the probability they actually have the disease is \frac{90}{8392}= 10.8%. That might seem surprisingly low but it is much higher than the original 0.98%.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> On its face it doesn&#039;t seem to make much sense because it doesn&#039;t even put you below the 1% chance you have HIV if your a male in the USA according to the CDC. So that does that really mean that being a male in the USA according to the CDC makes you less likely to have HIV than being a person who tests negative on the swab test? It might be comparing apples and oranges because the 1/13 number assumes every one of the 13 has HIV but it would still be useful to compare them.<br /> <br /> But using the 1% statistic and assuming the person is a randomly selected individual of that demographic it seems (logically) like the possibility would be reduced from 1% if someone of that category tested negative on the test. It seems like a compound statistical problem, is there a way of calculating how far below 1% a person who has tested negative on the swab test now has of having HIV using these two statistics? One statistic it looks like assumes every person being tested is HIV positive and the other one is a random sample of all males in the US of a particular demographic but it would be informative to use them to be able to derive this i just don&#039;t know if they can be because i was told if you use the rule of multiplying statistics they have to be of the same group and add up to 100. I think it depends whether the probabilities represent independent or dependent events. Which category do these two events fall into two? And how can they be manipulated to calculate how likely it is that the person has HIV if they fall into both categories? </div> </div> </blockquote>What &quot;categories&quot; are you talking about? I would think testing positive or negative but it is impossible for a person to test <b>both</b> positive or negative (at least on one test).<br /> <br /> - - - Updated - - -<br /> <br /> <blockquote data-attributes="member: 718639" data-quote="LostMinosHeins" data-source="post: 6776615" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> LostMinosHeins said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> According to the CDC 1 out of 102 persons who are males of a particular demographic have HIV. That mean&#039;s there is 1/102 = .98 * 100 = 1% chance of having HIV. </div> </div> </blockquote> .98 *100 is 98, not 1% but what you mean is 1/102= 0.0098 which 0.98% which is approximately 1%<br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> There is a swab HIV test available that is 91.7% accurate at being able to identify HIV positive people. This means that 12 out of 13 people who are HIV positive will test positive on the test. <br /> <br /> So say a person takes this HIV test and they fit into the demographic of the CDC statistic. If 1/13 people who are HIV positive tests negative on the test, it seems there is an 8.3% possibility that any person taking the test in general period is HIV positive, is that correct? </div> </div> </blockquote> I&#039;m not sure what this is supposed to mean.<br /> Suppose we have 10000 people. 10000/102= 98 people who have the disease. That is 98/10000= 0.98% just as you said above. You haven&#039;t yet said anything about testing positive or negative on this test. Saying that the test is &quot;91.7% accurate&quot; means that 91.7% of people who have HIV will test positive and 91.7% of people who do not have it will test negative. (It is more common to have different percentages for these two cases but this may be a simplification.) Of the 98 people who have the disease, 91.7% of them, 98(0.917)= 90 will test positive and or the remaining 10000- 98= <span style="font-family: 'Verdana'">99902,, 100- 91.7= 8.3%, .083(99902)= 8292, will also test positive. So a total of 90+ 8292= 8382 people tested positive of whom 90 actually have the disease. If a person tests positive on the test the probability they actually have the disease is \frac{90}{8392}= 10.8%. That might seem surprisingly low but it is much higher than the original 0.98%.&lt;br /&gt; &lt;br /&gt; &lt;blockquote data-attributes=&quot;&quot; data-quote=&quot;&quot; data-source=&quot;&quot; class=&quot;bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch&quot;&gt; &lt;div class=&quot;bbCodeBlock-content&quot;&gt; &lt;div class=&quot;bbCodeBlock-expandContent js-expandContent &quot;&gt; On its face it doesn&amp;#039;t seem to make much sense because it doesn&amp;#039;t even put you below the 1% chance you have HIV if your a male in the USA according to the CDC. So that does that really mean that being a male in the USA according to the CDC makes you less likely to have HIV than being a person who tests negative on the swab test? It might be comparing apples and oranges because the 1/13 number assumes every one of the 13 has HIV but it would still be useful to compare them.&lt;br /&gt; &lt;br /&gt; But using the 1% statistic and assuming the person is a randomly selected individual of that demographic it seems (logically) like the possibility would be reduced from 1% if someone of that category tested negative on the test. It seems like a compound statistical problem, is there a way of calculating how far below 1% a person who has tested negative on the swab test now has of having HIV using these two statistics? One statistic it looks like assumes every person being tested is HIV positive and the other one is a random sample of all males in the US of a particular demographic but it would be informative to use them to be able to derive this i just don&amp;#039;t know if they can be because i was told if you use the rule of multiplying statistics they have to be of the same group and add up to 100. I think it depends whether the probabilities represent independent or dependent events. Which category do these two events fall into two? And how can they be manipulated to calculate how likely it is that the person has HIV if they fall into both categories? &lt;/div&gt; &lt;/div&gt; &lt;/blockquote&gt;What &amp;quot;categories&amp;quot; are you talking about? I would think testing positive or negative but it is impossible for a person to test &lt;b&gt;both&lt;/b&gt; positive or negative (at least on one test).</span>
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
