Probability that the electron is found at a distance greater than r
The discussion revolves around calculating the probability of finding an electron at a distance greater than r=2a0 from the hydrogen atom's center in its ground state. Participants express confusion regarding the appropriate wavefunction to use for this calculation. The correct approach involves using the ground state wavefunction and integrating the square of it from 2a0 to infinity to find P(r>2a0). The radial wavefunction for the hydrogen atom, R10= 2/(sqrt(a0^3))*e^(-r/a0), is suggested as a suitable option for this calculation. Understanding the integration process and the correct wavefunction is essential for solving the problem accurately.
hansbahia
The problem given is to calculate the probability that the electron is found at a distance greater than r=2a0 from the center of the hydrogen atom in its ground state.
I don't understand what the problem is asking. I don't understand what form of the wavefunction I should use.
I know that to calculate the probability is P(r)= abs value (ψ(r))^2 or P(r)= ψ*(r).ψ(r)
but what wave function should i use in this problem? should i use e^(r/a0)/sqrt(pi.a0)?
i know that at the ground state n=1 in which makes n,l=0
Just take the ground state wavefunction and integrate the square from 2a0 to infinity, P(r>2a_0) =\int_{2a_0}^\infty \psi^*(r) \psi (r) dr
Thank you!
I have a question, in order to solve the same problem but if we use the wave function of the Radial functions of the Hydrogen atom is $$R10= 2/(sqrt(a0^3))*e^(-r/a0)$$ ?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
