Problem dealing with elastic collisions.
The discussion revolves around solving a physics problem involving elastic collisions between Minnie and Mickey Mouse. The key equations needed are conservation of momentum and conservation of energy, but the user struggles with determining the system's initial velocities. It's clarified that the conservation of energy can be used to find these velocities, as potential energy converts to kinetic energy during Minnie’s descent. The user is encouraged to apply these principles to calculate the distances and heights involved in the problem. Understanding these concepts is essential for solving the elastic collision scenario effectively.
dban33
Minnie mouse (mass m=37.5g) has run to the top of a curved frictionless wedge (height H1=1.15m) She slides down the track and makes a perfectly elastic collision with mickey mouse (mass m=69.8 g) who is at rest. Mickey flies off the table (height H2= .993 m) above the floor and minnie rebounds to a height H3 before she eventually falls off the table.
How far from the edge of the table, X1, does mickey land?
How high up, H3, does minnie rebound?
How far from the edge of the table, X2, does minnie land?
The equation I thought of using was M1V1i+ M2V2i=M1V1f + M2V2f.
This is not correct.
I tried to use the equation above but I do not know the velocity of the system so that made me stop. Is that the equation I use? I do not know where to start on this one because I do not have a starting equation to use.
Hi dban33! :smile:
For a collision between two bodies, you need two equations.
For any collision, one of those equations is conservation of momentum (that's the equation you quoted).
For an elastic collision (only), the other equation is (instantaneous) conservation of energy.
Have a go! :smile:
Ok good I am sortof on the right path then with the conservation of mometum equation. Is the conservation of energy equation V1i-V2i=-(V1f-V2f).
Both of these equations involve velocity though and I was not given that in the problem, where do I get that from?
Hi dban33! :smile:
Nooo … that equation's rubbish … burn it!
Conservation of energy is KE + PE = constant.
You'll get the velocity from the conservation of energy equation (the PE doesn't involve velocity). :wink:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
