Problem: Estimating pressure of compressive garment
  • Thread starter Thread starter qwertypie
    Pressure
The discussion focuses on estimating the pressure generated by active compression garments using shape memory alloys, specifically Nitinol, which can recover strains of about 6%. The pressure is created through the actuation and subsequent release of the fibers, similar to passive compression garments. Key considerations include the nature of the fabric weave, the arrangement of fibers, and the need for biaxial stress-strain experiments to accurately model the garment's performance. An equation for hoop stress was mentioned, but it may not accurately reflect the complexities of the material's behavior. Overall, a more comprehensive theoretical approach is necessary to predict the garment's properties effectively.
qwertypie
Basically, I'm working on a project to make active compression garments instead of passive. There are a few materials that can actuate with large recoverable strains, and I want to use them to create the compression. I need to estimate how much pressure they could create based on the recoverable strain they are capable of producing though. This would be either by constricting upon actuation or expanding upon actuation and the pressure being generated upon release of stimulus as the fibers try to return to normal, like with regular passive compression garments. I just need a rough estimate, or just the idea of how I would model this.
Do you really think it's the radial growth and contraction of the fibers that causes the compression?
Are the fibers embedded in a matrix, or is it a fabric? Are the fibers single ply? What is the nature of the fabric weave>
It's using shape memory alloys. Just to have some numbers, an alloy called Nitinol can recover strains up to ~6% after a phase transition. Nasa developed a device for rock splitting that use modified nitinol expanding elements that were capable of generating stresses in excess of 1.5 GPa at only 2-3 percent corresponding strain. In the time waiting, I found an equation for hoop stress, equated the stress to the young's modulus of the material x the strain, and solved for pressure. But I imagine that's wildly inaccurate to the real situation, which would be a cross-hatched weave where the lateral fibers contain the SMA wires as a core and some cladding.
You need to do biaxial stress-strain experiments on the woven fabric, or you need some sort of theoretical development to predict the biaxial stress-strain properties from the fiber geometry, the weave geometry, and the frictional characteristics of the fibers.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
