Problem: flux through prism faces
  • Thread starter Thread starter PSantiago
    Flux Prism
To calculate the flux of a wind vector field through the lateral faces of a triangular prism, numerical methods using tools like Matlab or Octave can be employed. The flux through the top face can be determined by applying the divergence theorem, which states that the total flux through a closed surface is equal to the volume integral of the divergence of the vector field. Given that the flux through the bottom face is null, the flux through the top face will equal the total lateral flux. The challenge lies in approximating the vector field, which is only defined at specific points, necessitating interpolation or numerical integration techniques. This approach allows for the calculation of the desired flux despite the lack of a continuous function for the vector field.
PSantiago
I need help regarding a practical problem I'm facing. It's not a homework/coursework, It's a real-life problem.
I have the values of a vector field (wind) given in six coordinates in 3D space. Those coordinates are the vertices of a triangular right prism (looks similar to my problem: http://i.imgur.com/2TU7D.png).
I would like to find the flux of this vector field through each lateral face of the prism. The components of the vector field may be approximated by linear functions.
My goal is to find the flux through the top face, given that the flux through the bottom face is null.
I'm trying to solve this numerically, i.e., using tools such as Matlab/Octave.
How could I do this?
Any suggestion (a reference for a method, a similar example, etc.) is welcome.
Sorry if this isn't the best place to post this kind of question, but since it's about flux I thought it would be included in General Physics section.
I'm wondering how that can be anything but zero as well? Given the top and bottom faces are parallel and the flux is wind.
Is the wind moving in a curved path? Sounds like the maths would be horrible.
In fact, it's an application of divergence theorem; sorry for not mentioning this. That's why Petyab is right in suggest Gaussian surfaces.
I'm assuming that the volume integral of 3D wind divergence is null. Thus, the flux through the closed surface bounding the volume must be null. I know that the flux through bottom face is zero. Therefore, the flux through the top face must equals the total lateral flux.
Despite the relevance of those assumptions, my point is how to numerically find the fluxes considering I don't have a function for my vector field. Moreover, I have the vector field given only in specific points in space.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
