MHB Problem on Graph Theory and Algorithms
The discussion revolves around the properties of connected graphs and the concept of "good" graphs, which require at least two distinct vertices such that removing each results in connected subgraphs. The user has successfully demonstrated that any connected graph is good by using its spanning tree to find two leaves. However, they are struggling with part (i) of the problem, which asks for a proof regarding subgraphs. Another participant points out that the user's initial assumption about the relationship between a graph and its subgraph is incorrect, providing a counterexample. The user acknowledges this mistake and reveals the source of the problem, indicating a collaborative effort to clarify the concepts in graph theory.
Chinta
The problem is as follows:
Let G be a connected graph.
For a vertex x of G we denote by G−x the graph formed by removing x and all edges incident on x from G. G is said to be good if there are at
least two distinct vertices x,y in G such that both G − x and G − y are connected.
(i) Show that for any subgraph H of G, H is good if and only if G is good.
(ii) Given a good graph, devise a linear time algorithm to find two such vertices.
(iii) Show that there exists a graph G such that we cannot find three distinct vertices
u1,u2,u3such that each of G − u1,G − u2, and G − u3 is connected.
I have approached to some extent. Here is what I've done:
If G is a connected graph then we can easily find its spanning tree and then removing any two leaves x and y from the tree one at a time gives us 2 another graphs G − x and G − y such that they are both connected.
"Hence any connected graph G is a good graph."
1. I'm stuck on how to solve part (i).
2. I have designed the algorithm for the part(ii) which extracts the spanning tree from G and then finds two such leaves x and y. Clearly
it is linear in terms of #vertices(=n) & #edges(=m) i.e. O(n+m)
3. I have also solved the third part with a graph as follows:
O------------------O-----------------O
In the above graph G we denote three vertices as u1, u2, u3. The edges are (u1,u2) and (u2,u3). Clearly G − u2 is not connected.
Please help me in solving part(i).
Thanks in advance :)
For a vertex x of G we denote by G−x the graph formed by removing x and all edges incident on x from G. G is said to be good if there are at least two distinct vertices x,y in G such that both G − x and G − y are connected.
Hi Chinta, :)
I think the first statement that you want to prove is in fact a false statement. For example take \(H=C_{4}\) where \(C_{4}\) is the cycle graph of four vertices. Now let \(G\) be the graph obtained by adding a single vertex to \(H\). Then it is clear that \(H\) is a sub-graph of \(G\). However, \(H\) is a good graph but \(G\) is not a good graph.
By the way can you please tell me where you found this question? :)
Kind Regards,
Sudharaka.
Actually I've got this answer that the question was wrong right after I posted the problem here a long time ago...I myself figured it out but forgot to post it here. :D
Anyway thanks for your solution too.
I got this question from a graph theory tutorial in internet actually.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
